DJI Mini 3 PRO RC Pair Button Issue
1706 4 2023-1-31
DJI_JOEY
Flight distance : 4432 ft
India
Hi,
I recently purchased a DJI M3 PRO with RC remote.
Last night while firmware update, aircraft battery died, and since then, I am not able to pair the Aircraft to RC.
Steps I tried:
1) Updated to latest firmware using Dji Assistant 2 (consumer) on both AC, RC and all batteries. but did not work.
AC firmware: v01.00.450
RC firmware: v01.02.300
2) Tried to pair AC to RC, but Pair button is not working. Every time I get error prompt: "Ensure the Aircraft is powered on and in pairing mode" (although I have done both)
Pair button is not clickable on the RC.
Please help!! Anything.
2023-1-31
DAFlys
Have you tried to refresh the AC firmware with the DJI Assistant?
2023-1-31
DJI_JOEY
India
Yes I have already did refresh the AC and RC firmware.
When I try to connect to any other AC other than DJI M3 Pro, it prompts for a firmware update, but it gives error "firmware update timed out, check device connection" (even after the RC is connected to WiFi).
I have tried both with Router WiFi and Hotspot connection.
When I tap on Pair button, nothing happens. Tapping on pair button IS NOT prompting 60 sec count down.
2023-1-31
DJI Susan
DJI_JOEY Posted at 1-31 08:23
Hi there, sorry for your issue. Please back up the needed files on the DJI RC and sync the flight records to the cloud, then perform a factory reset: Swipe down from the top of the screen. Click the “Settings” icon on the top-right corner. Select “Settings” --> “System” --> “Reset options” --> “Erase all data (factory reset)”.
After that, please try to refresh the firmware for the DJI RC via DJI Assistant 2.
If the linking can still not be initiated, you may consider sending it back for further service.
Please click https://www.dji.com/us/service/repair to start an online repair case.
2023-1-31
fansc6a814b6
Flight distance : 11401 ft
Hello,
Exactly the same issue, brand new drone and RC used 4 times . HAs anyone found a way to fix it? I have erased data 10 times, refreshed the firmware.....
2023-7-15
