O3 Air Unit wont enter binding mode
4381 13 2-1 06:21
BreakerX
Flight distance : 174 ft
i have a new pair of the DJI FPV Goggles v2 and a new O3 Air Unit.
i registered both devices.
i upgraded to newest firmware for both devices.
when i push the bind button on the O3 Air Unit, the green light doesnt turn red or do anything.
subsequently since air unit wont go into binding mode, i cant bind to goggles.
help
2-1 06:21
DJI Natalia
Hi, there. If you are unable to enter the linking status, please confirm whether the O3 Air Unit is activated, if it is activated, you can connect the computer and try to refresh the firmware again. If you still cannot solve this problem after refreshing the firmware, you are advised to send it back for detection. Here is the link to start a case: https://repair.dji.com/repair/index
2-2 02:30
BreakerX
O3 Air Unit has been activated.  i have connected the Air Unit to the computer and updated the firmware and refreshed the firmware several times.  i will try again.
2-2 07:26
BreakerX
BreakerX Posted at 2-2 07:26
the issue of why the O3 Air Unit wont enter binding mode has been solved.
this issue is due to how the O3 Air Unit is powered.  if you try and bind the O3 Air Unit while powering it via the USB C port, the O3 Air Unit will not go into binding mode.  If you try and bind the O3 Air Unit while powering it through the power input from the Flight Controller/ESC, the O3 Air Unit WILL go into binding mode and bind quickly to the goggles.
SUCCESS!
2-2 09:31
DJI Natalia
BreakerX Posted at 2-2 09:31
Hi, there.
We are glad to know that your problem is resolved and thanks for your update as well.
2-3 00:35
Smael
Flight distance : 1449190 ft
Morocco
Another issue hère please
My o3 green light only when connect via type c USB and no light no bind when powering the quad , normally without crash and Never crashed
it was working perfecto ? IS it normal dji ? Please
4-25 01:38
DJI Wanda
Smael Posted at 4-25 01:38
Hello, there. Sorry for the inconvenience. Would you please record a video for us about the issue you said?
4-25 04:26
fans7d490525
I have the V2 goggles and they were working fine for about a week until yesterday i went to fly and the goggles said "image transmission signal lost."  My 03 air unit wont to into binding mode either.
6-2 08:13
fans7d490525 Posted at 6-2 08:13
Hi there, could you please visit the video through the link below and try again to see if it works? You may also update/refresh the firmware for a test. If it still not works, please provide us with a video for further confirmation.
6-3 00:33
Aziret
could i bind gl300f(controller from phantom 4 pro) to dji o3 air ?
6-12 07:59
Aziret Posted at 6-12 07:59
Hi there, we are sorry to tell you that the Phantom 4 Pro remote controller is not compatible with DJI O3 Air Unit. You can consider DJI FPV Remote Controller 2.
6-13 00:50
Kuiko
i have the same problem, i buy a cinebot 30 last week whit o3 air unit but when i try to bind whit googles the light is solid green
i send to you a MP DJI Mindy
It is so sad
8-1 12:30
Kuiko
i solved this isue. i reset the googles v2 to the menu, after that i can bind.
Now i have a conection, i see the osd information bud dont see the camara imagen. Just a mesage "budtx"
i dont know what is that, some cable conection?
8-2 05:19
Kuiko Posted at 8-2 05:19
Hi there, sorry for the late reply. Please make sure the cable connections are correct. You may also refer to the videos below. https://www.dji.com/o3-air-unit/video
8-3 01:20
