Canon Eos 5D MkIV
2672 5 2023-2-3
CotsworldPix
Flight distance : 1063488 ft
How do I connect the Canon EOS 5D MkIV to the Ronin RS3?
2023-2-3
DJI Gamora
Hi, CotsworldPix. Thank you for reaching out. Are you trying to connect it physically? To mount your camera to DJI RS 3, you may follow this video:
Hope this helps. Thank you for your support.
2023-2-3
CotsworldPix
DJI Gamora Posted at 2-3 19:45
Hi, CotsworldPix. Thank you for reaching out. To mount your camera to DJI RS 3, you may follow this video:
https://www.youtube.com/watch?v=Ew_VQI_jwxc&list=PL65kukZorPdNt4xElKapvJIk1IptVJAwb&index=6. Hope this helps. Thank you for your support.
Thank you however I don’t mean physically connect a camera, but communication between the 5D and the Ronin.
The 5D does not have Bluetooth so I assume a cable is required. There are two ports on the 5D - mini HDMI and  USB 3.
2023-2-3
CotsworldPix
I have connected a cable from the camera to the Ronin and tried all three ports. The only port that does anything is the ‘RSS’ port. All this does is disable the camera?
2023-2-5
djiuser_CWS2idzfENIZ
CotsworldPix Posted at 2-5 08:32
Did you ever get a fix for this.
I just recived mine and am having the same issue.
2023-3-25
CotsworldPix
djiuser_CWS2idzfENIZ Posted at 3-25 11:43
You need a cable from the RSS port on the RS3 to connect to the lower part only of the USB 3 port on the 5D. I bought this cable: https://www.amazon.co.uk/dp/B07C ... t_b_product_details
2023-3-26
