alexa456
Pakistan
To connect your DJI RCPro controller to a TV or monitor, you can use an HDMI cable. Simply locate the HDMI port on your controller and connect one end of the cable to it. Then, plug the other end of the HDMI cable into an available HDMI port on your TV or monitor. Make sure to select the corresponding HDMI input on your TV or monitor, and you should be able to see the RCPro's display on the larger screen. This connection allows for a better viewing experience and easier control while operating your DJI drone. check for more tech tips on tecale here is a link
https://tecale.com |
