signal perdu
tchoo
Bonjour,
Je n'arrive plus a connecté mon drone et ma console, il m'est indiqué SIGNAL PERDU, le drone clignote en vert et rouge mais rien ne se passe
il a fonctionné parfaitement avant. (mon appareil est un DJL MINI SE)
Hello,
I can't connect my drone and my console, it says LOST SIGNAL, the drone flashes green and red but nothing happens
It worked perfectly before.(my device is a DJL MINI SE)
2023-2-9
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we are deeply sorry for the trouble that this has caused. Can you please confirm if the unit experience a hard landing before? Furthermore, kindly please try to enable WiFi or internet service and check if there's an available firmware update via the DJI Fly app. If you could provide us with a screenshot showing the error message, that would be very helpful. Please keep us posted. Thank you.
2023-2-9
tchoo
Bonjour,
Merci pour cotre réponse
J' ai activé/désactivé plusieurs fois le WIFI sur mon smartphone, cela n'a rien changé
je vous joint une copie d'écran. Je fonctionne avec LITCHI, l'application DJL Fly ne fonctionne pas sur mon smartphone GALAXY A
J'ai essayé avec un autre smartphone et l'appli DJL FLY le résultat était le même
Ci-joint une copie d'écran
Hello,
Thank you for your answer
I have activated/deactivated the WIFI on my smartphone several times, but it has not changed anything
I am attaching a screenshot. I work with LITCHI, the DJL Fly application does not work on my GALAXY A smartphone.
I tried with another smartphone and the DJL FLY app the result was the same
Here is a screenshot
2023-2-10
tchoo
2023-2-10
tchoo
Ma réponse vous laisse sans voix?
My answer leaves you speechless?
2023-2-25
DJI Paladin
tchoo Posted at 2-10 03:26
Bonjour,
Thank you for your response. Can you please send us the screenshot where it shows the error message on the DJI Fly app and not the 3rd party application? Please keep us posted. Thank you.
2023-2-25
tchoo
Hello,
L'application DJL fly ne fonctionne pas sur mon smartphone
J'ai trouvé le problème
Il provenait de la carte mémoire, qui avait pourtant posée aucun problème jusque là
Sans cette carte le drone se connecte sans problème
La carte contenait des fichiers photos et vidéos prises prises précédemment avec le drone
J'ai effacé les fichiers, reformater la carte et tout refonctionne parfaitement
C'est l'essentiel
Peut-être avez vous une explication?
Bien à vous
Hello,
The DJL fly application does not work on my smartphone
I found the problem
It was the memory card, which had not been a problem until now
Without this card the drone connects without any problem
The card contained photo and video files taken previously with the drone
I deleted the files, reformatted the card and everything works fine again
That's the main thing
Maybe you have an explanation?
Kind regards
2023-3-4
