Enterprise Smart Controller Charging
5742 8 2023-2-9
MichaelSciAv
Hello, I have a Matrice 300 RTK drone with the Smart Controller with the built-in extension for hot-swappable batteries.  The internal battery has run down, and this is normally charged by the external batteries when connected.  It seems this only works while the remote is on, but it shut itself off automatically without really charging.  Now it has stopped booting at all, with only a blinking LED when the power button is pressed.  According to a manual I found online, it seems like the internal battery should be able to charge from the USB-C port on the extension, but this has not worked for me.  How can I charge this remote now?
2023-2-9
Johnnokomis
Flight distance : 13349895 ft
Yes the external battery is only charging the internal battery while the RC is powered on. This is a dumb design choice by DJI in my opinion. You can charge by the USB C port on the side of the RC but I've found that it is really picky about what USB brick is being used. Your normal low watt iPhone USB adapter isn't going to cut it. Find a higher wattage plug and it should work.
2023-2-9
Arnor
Flight distance : 2660509 ft
Belgium
Johnnokomis Posted at 2-9 21:45
You have to use the provided USB charger you got with your M300 or RC. Other won't charge as W is not enough.
2023-2-10
Johnnokomis
Arnor Posted at 2-10 01:47
Which kind of removes "Universal" from the name "Universal Serial Bus".
2023-2-10
Arnor
Belgium
Johnnokomis Posted at 2-10 04:39
Universal connector but it needs lots of juice...form vs function? :-)
FYI I quickly scrolled through the Wikipedia USB-C, the voltage and Amp are not standardised :
"All USB-C cables must be able to carry a minimum of 3 A current (at 20 V, 60 W) but some can also carry high-power 5 A current (at 20 V, 100 W)" src. https://en.wikipedia.org/wiki/USB-C
2023-2-13
Johnnokomis
Arnor Posted at 2-13 22:21
Right but a slow charge is actually better for a batteries health (trickle charging?) These are only 3.7V 18650 cells inside most DJI RC's after all.
2023-2-14
Arnor
Belgium
Johnnokomis Posted at 2-14 04:56
ps : I only charged my 2 RCs like 2 times ever :-) Always using the external battery
2023-2-15
djiuser_Gh0WqIB2aMwI
Flight distance : 1090463 ft
Nigeria
Please I need help on this same issue call 07061510577
2023-4-8
Nigeria
Please i need help on this same issue. 07061510577
2023-4-8
