external mic
3027 35 2023-2-10
alloffroad
Flight distance : 6339409 ft
I honestly like the Osmo 2 and 3 however, why in the world can't DJ make a very good product instead just a good one?.
I need an external Mic solution for my Actions, the cumbersome dongles for the action 2, which are always not to find when you need them, and also are loose as and often fall out, are a pain. I was hoping with Action 3, this would get easier (how good would it be to have a standard 3.5 input).
Even worse, Action 3 does not work with its own DJI Mic line-up (no receiver needed), and every USB-C to 3.5 adapter I have purchased so far (2) does not work.
DJI does not even have one for sale on its website.
Any suggestion for a working USB c to 3.5 adapters?
2023-2-10
johansenfoto
Flight distance : 1173379 ft
Norway
BOYA BY K4 is one that work.
2023-2-10
lutzmix
Boya BY k4 has a TRS plug
2023-2-11
lutzmix
TRRS Adapter
2023-2-11
lutzmix
you can the DJI mic receiver plug direct in the usbc port
or try a BT dongle
yt channel Andreas Dück
https://forum.dji.com/forum.php?mod=viewthread&tid=284653
I use a wireless Smallrig Wave C1 , but the signal to the cam is a bit low
2023-2-11
alloffroad
ok think TRRS is no good just watched a video with a comparison needs to be TRS
2023-2-11
alloffroad
lutzmix Posted at 2-11 00:39
thanks I just found them and ordered two, not sure why we need this dongle crap put a 3.5 mic jack in and allow proper audio controls and done with it. This would be even bigger reason to forgo GoPro.
2023-2-11
Mikedefieslife
Flight distance : 6627 ft
The USC-C to 3.5 adapters need to have DAC IIRC as the camera doesn't have one built in. It's a way saving space and money from the manufacturer. As you see with phones, most are doing the same thing.
2023-2-11
alloffroad
Mikedefieslife Posted at 2-11 01:26
yea a Phone no issue a Camera is not much good without good audio so saving at the wrong places. personally also rather have a slightly bigger Camera and no need to carry dongles
2023-2-11
alloffroad
hm this sounds interesting then
https://www.amazon.com.au/MoonDr ... s%2C527&sr=8-13
2023-2-11
Fishycomics
well at least its not an Insta 360  camera that uses apple air pods that can not   work pass 1 feet Lol
2023-2-11
lutzmix
alloffroad Posted at 2-11 01:14
trrs is possible but low input
https://youtube.com/shorts/rE8sFN3yPS8
2023-2-11
Fishycomics
cameras we know uses TRS, smartphones we know uses TRRS, so why are we always looking at smartphones products for cameras, are they cheaper, do they work the same, better, worse,  I rather use the propper cables for the propper item, then pick up the wrong cable and  hear back here, why did not my camera ado what it was supposed to di. and then after all these guessing games.
C O F F E E   time.  Yes I get what we all are saying
DJI makes the product or products we still be asking.. thanks all
2023-2-11
johansenfoto
Norway
alloffroad Posted at 2-11 01:18
With GoPro you need either Media Mod that is expensive or a usb to 3,5 adapter for GoPro that is crap.
It is a pain to use Media Mod on GoPro, I hated it.
2023-2-11
tojjer
This one works ok:
2023-2-11
alloffroad
Fishycomics Posted at 2-11 05:20
problem most adapaters dont even state if they are TRS or TRRS
2023-2-11
Fishycomics
why we pay attention to detail, I say? (SMILES)
2023-2-11
Rocktheasphalt
TRRS USB-C adapters are usually used for smartphones, often reducing the volume gain (and only mono audio). Useful for the Osmo Action 3 if u have a sensitive TRRS mic for Smartphones. The combination of both makes good audio. If you use a BOYA adapter (can do stereo, but useless for most cases) with a sensitive mic like the RODE Lavalier II (TRS), it will be clipping inside a helmet. If you combine the BOYA adapter with a less sensitive mic, you will also have less clipping. In case you don't know, those "adapters" are actually soundcards...
2023-2-11
alloffroad
Fishycomics Posted at 2-11 13:17
can't pay attention if there is no detail
2023-2-12
alloffroad
So in reality, good external audio is not really possible with the Action 3 it seems.
Just to save someone else the hassle, I purchased one of these but it does not work at all actually if plugged in
the Action 3 won't operate, cant start or stop recording etc.
2023-2-12
alloffroad
This one does also not work
2023-2-12
alloffroad
any link? does not show up on Amazon or Ebay here in OZ
2023-2-12
Rocktheasphalt
I tested some USB-C to 3.5mm TRRS adapters in this video. Be sure to buy the original. Links to working adapters in video description.
2023-2-13
lutzmix
Samsung TRRS Adapter aus China
Mobile Mate Arena shop
funktioniert bei mir mit ,Andoer AD,-M2 mic Niere
Verstärkung in der Kamera -5db
angeblich original
das Andoer AD-M1  Kugel Lavalier mic geht auch
Samsung TRRS adapter from China
works for me with ,Andoer AD,-M2 mic cardioid
Gain in the camera -5db
allegedly original
the Andoer AD-M1 omnidirectional lavalier mic works too
2023-2-13
johansenfoto
Norway
alloffroad Posted at 2-12 16:34
That cable is for headphones, not mic if you was after a mic adapter?
2023-2-13
lutzmix
johansenfoto Posted at 2-13 11:01
it is a try and error
it is difficult to find a working adapter
best is the Boya by k4 trs adapter
use yt and you can find some working adapter
2023-2-13
johansenfoto
Norway
lutzmix Posted at 2-13 11:05
That's true.
Also think there is one from Saramonic
2023-2-13
lutzmix
johansenfoto Posted at 2-13 11:18
That's true.
saramonic sr-c2001    about 20 dollars
haven't tried it myself
2023-2-13
lutzmix
lutzmix Posted at 2-13 08:57
[Image]
cam 1 Osmo Action intern mic 61sec
last 27 sec cam 2 Osmo Action 3 with china samsung trrs adapter mic andoer m2  camera gain +10 db
sound level is original
2023-2-14
4wd
Flight distance : 545817 ft
The boya adapters seem hard to find in Europe they are on ali express but even there don't show you on search properly
https://www.aliexpress.com/item/1005003834918943.html?
2023-2-15
lutzmix
you can try a no name k2 adapter
my boya by k7 and oa1 are from Ali
cocogear store dont send now to EU Embargo
2023-2-15
lutzmix
Boya BY-K4  Amazon uk 30€
sept 2022 I paid 18€
2023-2-15
lutzmix
lutzmix Posted at 2-14 23:59
now with boya k4 adapter
mic and camera gaine is equal
10db is to high
trs
B1JcOTy3AR4
trrs
2023-2-15
Fishycomics
https://amzn.to/3I1VWuj
Boya BY-K4 $18.**
✅ 3.5mm Input for any microphones which feature a 3.5mm mic male jack. Such as BY-MM1, BY-WM4, BY-WM2G, UWMIC9, BLINK500, BY-WM8 PRO etc
✅ USB-C Input for type-c devices, such as smartphones.
https://amzn.to/3Xza1oL   $18.**
for your rode wireless go
2023-2-15
lutzmix
samsung china trrs adapter + andoer m1 mic
camera gain -5db works well
andoer m1 and boya m1 look similar
boya m1 in EU 15-20€
you can use trs+ trrs adapter
you need one lr44 battery
6m cable
the boya m1 pro has a -10db gain switch
2023-2-15
tojjer
alloffroad Posted at 2-12 16:39
https://www.ebay.co.uk/itm/195254578854
2023-2-16
