Unable to update RC-N1
5046 16 2023-2-10
djiuser_jacob_b
Flight distance : 898957 ft
Firmware stuck on V02.00.1200 on RC-N1. I cannot update from the iOS or iPadOS DJI Fly app (Server error 0×115000100002), nor from macOS DJI Assistant 2 (Consumer Drones Series) V2.1.16, or from Windows DJI Assistant 2 (Consumer Drones Series) V2.1.16. Have been trying daily for the last week to update and pair to Mavic 3. Apparently the most current controller version is 04.xx.xxxx (DJI Support)
I am really frustrated after spending $1500 USD on a Mavic 3 and not being able to pair it to a controller, and am now out of options. Is my controller bricked? Is there anything I can do???
DJI FLY>Profile>Settings>Check for firmware updates>> Server error 0×115000100002 (see attachment)macOS Assistant 2>DJI>RC-N1>Firmware Update>> V02.00.1200 as current and no Flight Logs???? (see attachment)
Windows Assistant 2>DJI>RC-N1>Firmware Update>> V02.00.1200 as current and no Flight Logs????
iPhone 11 Pro (DJI Fly V1.9.1)
iPad Pro 2022 (DJI Fly V1.9.1)
macOS 13.1
Windows 10
macOS Assistant 2
macOS Assistant 2
iOS DJI FLY
iOS DJI FLY
2023-2-10
DJI Wanda
Hello, there. Sorry for the inconvenience. May we know if you get any notification to update the firmware of the remote controller in the DJI FLY APP when connecting RC-N1 to your phone?
2023-2-10
djiuser_jacob_b
No there is no notification like that
2023-2-11
Platano137
I have the exactly same problem.
2023-2-18
DJI Tony
Platano137 Posted at 2-18 06:18
[view_image]
Hi there. We're sorry you're experiencing the same concern. We recommend you update the firmware through the DJI Fly app. On the DJI Fly app, select "Connection Guide," select your aircraft model, and the app will prompt the firmware update notice. Once it completes the update through the app, you may try the DJI Assistant 2 software again. Please keep us posted. Thank you, and have a nice day.
2023-2-19
djiuser_2M6OHqCX7TvX
Did anyone managed to sort this issue please
2023-4-22
DJI Tony
djiuser_2M6OHqCX7TvX Posted at 4-22 08:30
Hi there. We're sorry for the inconvenience. If you are experiencing the same concern, please refer to the instructions posted in reply #5. If the issue persists, please let us know. Thank you.
2023-4-22
FTrindade
Flight distance : 395456 ft
Portugal
I have EXACTLY the same issue.
I would like to use my RC-N1 that is bound to my mini 2 with my new miji 3 pro and when I choose the mini 3 Pro from the list, it says uncompatible firmware but then it always crashes.
Messages vary from network error (and my network is fine, thank you) to some other messages of server wrror.
I am able to connect to ALL DJI sites and update all my other devices EXCEPT my RC-N1.
I am really mad now.
2023-5-7
shaneZhang
Flight distance : 4596 ft
Have the same problem, DJI Fly app can not show the RC firmware version (N/A), and DJI Assistant 2 can show the firmware version, but can not show available firmwares.
2023-5-8
alejandrogalaxy
tengo el mismo problema no puedo actualizar el mando con el firware para utilizar el mini 3 desde la aplicacion fly dji desde apple necesito solucion porfavor
2023-5-18
Guigoruiz1
Flight distance : 235039 ft
I have the exact same problem with a mavic air 2. Has anyone ever solved this?
2023-5-30
djiuser_zKR5HFX3a2EC
Flight distance : 474537 ft
Guigoruiz1 Posted at 5-30 11:08
Yes i have. You need to delete the fly app on your phone or tablet. Then redown it again. Then connect to your drone. It will ask you to update. Click update and it should work.
2023-5-30
Guigoruiz1
djiuser_zKR5HFX3a2EC Posted at 5-30 12:51
That didn’t work for me. I got a prompt to upgrade the drone firmware but not the controller. It’s weird though since the drone was already up to date and it just reinstalled the same version. The controller still appears as N/A in the about tab
2023-5-31
SzJ
Flight distance : 612999 ft
Hungary
Totally same here, no solution.
All we have controller with green leds?
And dear, we cannot connet to the drone BECAUSE it had can not upgrade, to be able to connect!!!
UPDATE! solved!
check the AIRCRAFT firmware in the app on android!!!!:
it will update to next,
than tap connect to mini3 pro, and it will update the latest RC firmware.
Thats all!
2023-5-31
Benrider2002
Flight distance : 14951 ft
Hey, i had the same problem as all of you! I tried with my iPhone, my iPad and finally with the DJI Assistant 2 (Consumer Drones Series) on windows 11.
What is my answer for the problem? ANDROID! I downloaded the dji fly app on one of my friend's android and it updated the controller like a charm!
Hope it will be the case for all of you too!
2023-6-1
djiuser_jacob_b
SOLVED!!
To update your RC N-1 controller You Will Need An Android Phone.
I used a friends Z-flip 4 running Android 13 and the controller was then able to update itself in the app via Profile>Settings>Check for firmware updates. Once it has completed an update with the Android device, it will work like normal on all platforms with the usual software... DJI Assistant 2, DJI Fly, etc. The install process for this is rather convoluted (coming from iOS) but go to DJI>Support>Downloads>DJI fly. Click on the app icon and then agree to all the necessary android warnings and open the app. If I remember correctly I had to go into settings somewhere and allow app installs from outside the PlayStore or from unidentified developers or something. Best of luck!
So sorry, I figured this out in February and forgot to post a fix
Thanks Benrider2002 for the reminder!
2023-6-1
fans2b787f9d
Flight distance : 764180 ft
Sweden
SzJ Posted at 5-31 13:02
None of these advices worked but when I solved the problem by downgrading to the oldest firmware in the RCN1
2023-7-25
