Change the voltage of the high power pin on the Skyport V2 board ...
711 0 2023-2-12
djiuser_KtYl0gScr6EJ
The PSDK has the power management which should allow the application to request high power mode (switch from 13.6V to 17V). I have the following code:
    auto returnCode = DjiPowerManagement_Init();
[color=var(--ds-text-subtlest, #505F79)  !important]2
[color=var(--ds-text-subtlest, #505F79)  !important]3
    if (returnCode != DJI_ERROR_SYSTEM_MODULE_CODE_SUCCESS)
[color=var(--ds-text-subtlest, #505F79)  !important]4
[color=var(--ds-text-subtlest, #505F79)  !important]5
        USER_LOG_ERROR("could not init, error code: 0x%08X", returnCode);
[color=var(--ds-text-subtlest, #505F79)  !important]6
        return DJI_ERROR_SYSTEM_MODULE_CODE_UNKNOWN;
[color=var(--ds-text-subtlest, #505F79)  !important]7
[color=var(--ds-text-subtlest, #505F79)  !important]8
[color=var(--ds-text-subtlest, #505F79)  !important]9
    auto callback_val = [](E_DjiPowerManagementPinState pinState) -> T_DjiReturnCode
[color=var(--ds-text-subtlest, #505F79)  !important]10
[color=var(--ds-text-subtlest, #505F79)  !important]11
        std::cout << "Got pin state from callback " << pinState << "\n";
[color=var(--ds-text-subtlest, #505F79)  !important]12
        return DJI_ERROR_SYSTEM_MODULE_CODE_SUCCESS;
[color=var(--ds-text-subtlest, #505F79)  !important]13
[color=var(--ds-text-subtlest, #505F79)  !important]14
[color=var(--ds-text-subtlest, #505F79)  !important]15
    DjiPowerManagement_RegWriteHighPowerApplyPinCallback(callback_val);
[color=var(--ds-text-subtlest, #505F79)  !important]16
[color=var(--ds-text-subtlest, #505F79)  !important]17
    returnCode = DjiPowerManagement_ApplyHighPowerSync();
[color=var(--ds-text-subtlest, #505F79)  !important]18
[color=var(--ds-text-subtlest, #505F79)  !important]19
[color=var(--ds-text-subtlest, #505F79)  !important]20
        USER_LOG_ERROR(
[color=var(--ds-text-subtlest, #505F79)  !important]21
            "setting high power mode failed, error code: 0x%08X", returnCode
[color=var(--ds-text-subtlest, #505F79)  !important]22
[color=var(--ds-text-subtlest, #505F79)  !important]23
[color=var(--ds-text-subtlest, #505F79)  !important]24
        USER_LOG_ERROR(
This will run with no errors, but it does not change the voltage of the pin. I also ran the power mode change application:
| Start power management sample - you will see notification when aircraft power off            |
But this has the function to change the power mode with:
static T_DjiReturnCode DjiTest_WriteHighPowerApplyPin(E_DjiPowerManagementPinState pinState)
    //attention: please pull up the HWPR pin state by hardware.
How are we supposed to enable high power mode? How do we pull up the HWPR pin?
2023-2-12
