Samsung Note 20 Ultra 20 not pairng with action2
779 4 2023-2-13
kastaway
The phone did see the action2 camera in the past and not will not see it. Tried everything as written in the forum. The table sees it right away. The phone see the name and password, but will not connect.
2023-2-13
DJI Tony
Hi there. Thanks for reaching out. We're sorry you're experiencing such difficulties with your DJI Action 2. Here are some troubleshooting steps you may perform:
1. If the camera is inactivated, kindly activate it.
2. Enable the following permissions on the mobile phone:
a. Mobile phone location;
b. Location information;
c. GPS location.
3. Set the camera's WiFi Frequency depending on your location and mobile phone support.
If it only supports 2.4 GHz, set it to 2.4 GHz.
If it supports both 2.4 GHz and 5.8 GHz, set it to Auto (default).
Go to Settings - Wireless Connection - Wi-Fi Frequency.
4. Go to DJI Action 2 Wireless Connection page and on the mobile phone, go to Settings>Wi-Fi List and connect to the Wi-Fi signal started with Osmo Action.
5. If the mobile phone supports WLAN+/WLAN Assistant, disable the WLAN+/WLAN Assistant to prevent the mobile phone system from switching to Wi-Fi automatically.
6. Manually modify the IP address. Here's how:
a. Set the IP to DHCP (dynamic) and input 192.168.2.100 in the IP address column. Then, try again;
b. If the issue persists, switch it to a static IP to reconnect and retry;
c. Switch to DHCP (dynamic) and then input the IP. Reconnect to it.
7. Launch the DJI Mimo.
If the connection still fails, kindly post a short video showing the connection failure. We appreciate your understanding and cooperation.
2023-2-13
Bob Brown
Flight distance : 4209662 ft
Wrong forum. This is Avata.
2023-2-15
DJI Tony
Bob Brown Posted at 2-15 12:00
Hi, Captain. Thanks for pointing that out. We will be moving this thread to the right section. Have a nice day!
2023-2-15
DJI Tony
Hi, kastaway. Please be informed that we have released a new firmware update that will resolve this concern. We recommend you update the firmware of the camera and check. Please keep us posted. Thank you, and have a nice day.
2023-2-24
