Display brightness resets level to 1%
715 9 2023-2-15
ChadAustin
Flight distance : 139731 ft
Not that this is a huge deal... but everytime I turn on my RC Pro the display brghtness (which I usually set between 65-90%) is back down to 1%.
What is up with that?
2023-2-15
Mobilehomer
Flight distance : 18150351 ft
Auto brightness?
2023-2-15
ChadAustin
That's a great guess. I looked and "auto adapt" was toggled on... but the thing I experienced was it would be at 1% when I outside in the sun.
I turned the  adaption thingy off for now.
2023-2-15
Mobilehomer
Maybe the sensor has gone bad. Use Assistant 2 and refresh the firmware.
2023-2-15
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. When settings the brightness option to Auto on your DJI RC Pro, the brightness will be automatically adjusted to be suitable for human eyes based on the brightness of the external environment. As you mentioned that you are having issues with it outdoors, please try to set it again in "Auto" and then wait for a few minutes to see if the brightness will change. Please keep us posted. Thank you.
2023-2-15
DJI Tony
Hi there. In addition to DJI Paladin's suggestions, kindly ensure that the photosensitive sensor is not blocked during use.
If the issue persists, kindly post a short video showing the error for further checking. Thank you, and have a nice day.
2023-2-15
dreamtuner
Flight distance : 2232569 ft
Bangladesh
Do you have any kind of screen protector applied on the screen?
2023-2-16
ChadAustin
dreamtuner Posted at 2-16 05:44
Hi- no I do not have a screen protector.
That is true: I practice unsafe screen viewing
2023-2-16
dreamtuner
Bangladesh
ChadAustin Posted at 2-16 07:23
Well, that's weird then. It should not start at 1% unless you start it in pitch black which is not your case. I would contact DJI and have them take a look at it to if under warranty.
2023-2-17
DJI Paladin
Hello there. Can you please confirm if the issue still persists after the suggestions above? Please hit the "reply" button so we can be notified when you respond. Thank you.
2023-2-25
