Dji Terra Reconstruction Error 1073741845
4680 9 2023-2-17
Mik22
Flight distance : 142986 ft
Hi everyone, I've finished processing a survey, but dji terra can't reconstruct the 3d model. Could it be my PC that doesn't support rebuilding even though it was doing just fine until now?
2023-2-17
djiuser_oDdinTBDqSUP
Maldives
Same issue. Waiting for an answer.
2023-3-2
Geolux
same problem. Reding the log file, I understand that there was not more space on the HD where is allocated the Chasce of DJI Terra
2023-3-3
Mik22
I solved it thanks to the assistance.  You don't have to move the photo path.
2023-3-3
fans266b5533
Flight distance : 7523 ft
Hi, I have the same problem, how did you fix the problem?
Thanks
2023-3-3
djiuser_CxVp1icslRp1
Mik22 Posted at 3-3 10:42
What did you do to fix it?
2023-3-3
Mik22
djiuser_CxVp1icslRp1 Posted at 3-3 22:54
The official answer from DJI support for my case:
Our engineer already checked the logs and found the error code is 'wrong cache image exception',and they suggest you can try the below tips for troubleshooting frist .
After you import the photos into terra, have you moved the location of the original photo files or changed the name, if so, please do not do this operation.
2023-3-4
Samuelgomide
Flight distance : 55784 ft
Brazil
Hi!
I would like to identify what kind of error I'm having during the assembly of the orthomosaic in the reconstruction step using the DJI Terra.
The DJI Terra Agras version is: v.3.6.7. The license in use is the DJI Agras T10 Drone license, which comes with the product.
The error code is: Reconstruction error (1073741845).
2023-3-14
djiuser_q29qGXugvlSB
South Korea
I am also suffering from the same error. Help me. I also formatted it, but it's not convenient
2023-5-15
South Korea
2023-5-15
