DJI-Dave
![](https://forum44.djicdn.com/data/attachment/common/aa/common_14_usergroup_icon.png) Second Officer
If you're shooting fireworks or otherwise trying to capture bright features in a dark setting, like city lights at night, that sort of thing, you don't want the camera trying its ever loving best to bring up the dark and shadowy areas as if it were late afternoon. Because the camera really has no idea what you're looking at or what your intentions are, and it always uses whatever tools it has to try to make everything exposed as if it were looking at middle grey - not white, not black. So by limiting the ISO to no more than 400, and knowing that it can only open its shutter for just so long as it shoots video, you're forcing it to under-expose what it thinks it should be trying to make look like daylight. The result is that night actually looks like night, and bright things like fireworks or window lights or headlights or campfires will look pretty good, rather than being completely blown out highlights.
Night flight info:
Lock the ISO to 100 to avoid the noise and it should look pretty good. I would also lock the white balance as "daylight". Believe it or not, this will probably give you the best result (and WB can easily be edited in post especially if you have locked it and not left as AWB which can change a lot from image to image). |
