Mavic 3 - Straight paths between waypoints
3512 11 2023-2-22
fanse2f3b029
Flight distance : 2981932 ft
Russia
Hey everyone!
Is there a way to make paths between waypoints straight, not curved?
I'm running DJI Fly on iPad Mini 6.
2023-2-22
frankymusik
Flight distance : 27904331 ft
There is currently no option for this in the settings...
2023-2-22
djiuser_CgYhBqmxP83j
Flight distance : 1078150 ft
It seems to be based on POI for camera. I wonder if before setting point two you turn the drone from point 1 to look at point 2 and then turn it again before moving to look at points.
2023-2-23
fanse2f3b029
Russia
djiuser_CgYhBqmxP83j Posted at 2-23 06:09
Changing heading doesn't affect the curvature
2023-2-23
The Saint
Flight distance : 6260171 ft
wow, the biggest complaint about the autel mission (waypoints) is the paths are straight and not curved.  i should also add that straight on the autel mission means the drone must pause as it cannot immediately shift directions; not sure how it would ultimately get implemented on dji.  personally i prefer curved for the cinematic look.  i believe there are plans for autel to switch from straight to curved in a future release.
in the meantime, the best way to overcome these minor differences is to make your waypoint adjustments appropriately and then fix everything in post.
2023-2-23
Niknik
Flight distance : 1648806 ft
Greece
That is a good option to add in waypoints settings. Curved or straight. If DJI adds this option then it will be much easier to do mapping missions.
2023-2-23
djiuser_21vazN53a4oJ
Flight distance : 660751 ft
You can "export" your flight plan, import it into DJI Flighthub 2, change the lines from curved to straight, export it and import it back into DJI Fly.
A bit cumbersome, but it should work.
Alternatively you can create the flight plan in Flighthub 2 to begin with.
2023-2-24
fanse2f3b029
Russia
djiuser_21vazN53a4oJ Posted at 2-24 03:50
Thanks for the advice! I've seen this solution on YouTube, but the guy on video used the Android device for DJI Fly. I tried this hack with my iPad mini and it doesn't work.
2023-2-25
Isenseven38
Flight distance : 470807 ft
Can be really nice to add this option for creatives hyperlapses, please DJI
2023-10-22
DJI Tony
Isenseven38 Posted at 10-22 09:16
We appreciate your valuable suggestions. We will forward your feedback to the related department. Thank you for your great support.
2023-10-30
이건영
South Korea
djiuser_21vazN53a4oJ Posted at 2023-2-24 03:50
I tried it but it doesn’t work at all. Route seems straight but mixed with curved route.
2024-4-9
이건영 Posted at 4-9 21:47
Maybe they closed this loophole somehow. You still can manually change it in the wpml-file but only for certain turn parameters.
2024-4-10
