Mini 3 Pro forum?
2745 11 2023-2-25
Jiheffe
Flight distance : 276302 ft
Belgium
Hi,
Where is the right forum to post about Mini 3 Pro?
JF
2023-2-25
DJI Diana
Flight distance : 2408 ft
Hello, Jiheffe. Thanks for reaching out. Please go to Product > Mavic > DJI Mini 3 Pro. Kindly refer to the screenshot below. I hope this helps with your query. Should you have further concerns, you may keep us posted. Thank you for your support.
2023-2-25
PixelPro
Flight distance : 1205715 ft
Under the products section. Go to >products> new thread> Mavic< Mini 3 pro
2023-2-25
djiuser_Pd1cP6GOEpXP
Uruguay
Hello, my mini 3 pro connects and disconnected constant, a 1 meter distance between the mini 3 pro drone and the control of the RC screen. This happened after the Ultona Firmware Actulization I did. Is there no hay any solution for this yet? Does that happen to someone else?
2023-2-27
DJI Wanda
djiuser_Pd1cP6GOEpXP Posted at 2-27 12:01
Hello, there. Sorry for the late response. Would you please record a video for us?
We would like to further verify the issue.
Also, may we know did you test in different palces?
2023-2-27
Uruguay
DJI Wanda Posted at 2-27 19:17
hola si pruebo en 4 lugares diferentes y de todos modos el problema aun sigue.Dron fallido Mini 3 Pro
2023-3-2
Uruguay
https://drive.google.com/file/d/1ZHW9XzR-JFNyuLbGRbGd3H36jVxpBdwn/view?usp=sharing
Hello if I try in 4 different places and anyway the problem still continues.
2023-3-2
djiuser_Pd1cP6GOEpXP Posted at 3-2 15:12
Hi there, thanks for the video provided. May I ask if the firmware of the drone and RC is up to date? Could you please try to refresh the firmware through DJI Assistant 2 to see if the issue still exists? https://www.dji.com/mini-3-pro/downloads
2023-3-2
djiuser_6oAC1MVPem0y
Hi just bought some dji v2 goggles but bind mini 3 to them any advice how to get round this thanks in advance
2023-12-17
DJI Thor
Flight distance : 13602 ft
djiuser_6oAC1MVPem0y Posted at 12-17 13:03
Hi there, would you please provide us more specific details about the issue you encountered when you trying to bind the Google 2 and DJI Mini 3? Thanks.
2023-12-17
djiuser_5At6PV7ZlEvM
Flight distance : 681247 ft
How do you ask a question about mini 3 pro flight mode on this forum?
2024-12-25
DJI Wanda
djiuser_5At6PV7ZlEvM Posted at 12-25 12:28
Hi, there
Thanks for your question.
Please follow the steps as photos shown:
You also can ask the question here, we will check it further for you. Thanks
2024-12-26
