Clock off ???
926 4 2023-2-25
Jiheffe
Flight distance : 276302 ft
Belgium
So I did two flights this afternoon...
First one at 14h35 for a duration of about 16 minutes.
I then shut down the drone and controller, moved about a km, put in a fresh battery and took off again at around 15h00, I guess.
I write "I guess", because that second flight was recorded as taking off at exactly 13h00, and all photo EXIFs, etc... are wrong...
In   Airdata the second flight is recorded as if it happened first, and on   my PC all the photos and videos from the second flight are sorted  before  those of the first one.
Anyone had this also?
2023-2-25
The Saint
Flight distance : 5902228 ft
controller+mobile or controller only?
2023-2-25
Jiheffe
Belgium
The Saint Posted at 2-25 12:05
DJ Controller only (the one that ships with the Mini 3 Pro).
I should add it's the first time it happened in about 40 flights (I'm a rookie ;-) ).
2023-2-25
chrisvomradio
Flight distance : 3241519 ft
Exactely the same thing happened to me. 23 hours behind.
2023-2-25
Phil ZIMMER
Flight distance : 136552 ft
Belgium
Hello
I had a similar problem yesterday.
I've made some flights, and all photo and video footages have the date of 31st of March.
I noticed this only in the evening, when I was copying the files to my laptop.
Then I switched on my RC, and realized that its date and time were wrong.
The time came back to normal after I turned the WIFI on.
It's weird, and also the first time it happened after 3 months of usage.
2023-4-10
