CACHE INCREASE
623 3 2023-2-27
STOPSTU
Flight distance : 333323 ft
Drone: DJI MINI 3 PRO (Aircraft Firmware v01.00.0450 — updated 2/26/23)
Remote: DJI RC (app v1.9.4 — updated 2/26/23) (Remote Firmware v01.02.0400 — updated 2/26/23)
Fly Safe Data: App Static Safety Data v01.00.01.28 — updated 2/26/23, Aircraft Static Safety Data v01.00.01.27 — updated 2/26/23
SUBJECT: I need to be able to store more Map Data in my DJI RC's cache for use in remote locations where there is NO CELL RECEPTION and NO INTERNET.
QUESTION 1: Is it possible to increase the cache on the DJI RC so I can store more map data?
QUESTION 2: How do I increase the cache on the DJI RC so I can store more Map Data?  Would it require a higher capacity microSD?
Thank you for your help and fly safe!
Stu
2023-2-27
DJI Gamora
Hi, STOPSTU. Thank you for reaching out. Can you please confirm if you're pertaining to the Cache Maps in the Camera View?
2023-2-27
STOPSTU
Hi Gamora,
I wasn't aware there was a difference between the drone or the DJI.  Q1: Do they each store map info separately?
I'm referring to the map info I see popping up in the lower-left corner of the "Go Fly" (Camera View) Screen.  Most of the places I fly the drone have no cell reception and certainly no internet.  But I've learned that you can turn on the RC while on wifi or while connected to a Hotspot, pull up the map from the Camera View, and scroll around to the areas I intend to fly.  And then when I go out to the intended area to fly the drone, all the map info comes in perfectly and I'm even able to zoom-in.  But as soon as I get to the limits of an area I previewed, the map info is no longer clear and I can't zoom-in.
So I'm wondering...
Q1: how much "previewing" can I do for an area I intend to fly?
Q2: What are the cache limits of stored "map preview"?
Q3: Is there a way to change the size of that cache amount?  And see the size of that cache, or how much is devoted to map previews?
Q4: Is there a way to know when that cache is filled up or might get over-written?
Thank you for your help!
Stu
2023-3-8
Jake. A
Flight distance : 1205715 ft
you might be able to use an sd card
2023-3-10
