DJI Support
Flight distance : 2408 ft
Overview
- Date: 2023.09.20
- Aircraft Firmware: v07.01.20.01
- Remote Controller Firmware: v02.01.00.07
- DJI Pilot 2 App: v7.1.0.30
- DJI Assistant 2: v2.1.10
What’s New
- Added DJI Care Flyaway Coverage service.
- Added support for the EU C2 certification.
Notes:
- Restart the aircraft and remote controller after the update is complete.
- If the update fails, restart the aircraft, remote controller, and DJI Pilot 2 or DJI Assistant 2 (Enterprise Series), and retry.
- Make sure the firmware of the aircraft and the remote controller, and DJI Pilot 2 are the latest versions. Otherwise, usage may be affected.
Overview
- Date: 2023.08.29
- Aircraft Firmware: v07.01.10.03
- Remote Controller Firmware: v02.01.00.03
- DJI Pilot 2 App: v7.1.0.24
What’s New
- Added the function of Find My Drone, which can be used in scenarios such as aircraft emergency landing or flyaway to provide information such as position display and coordinate sharing.
- Added ability to view the downloaded photos and videos in Album when the aircraft is disconnected.
- Added ability to import unlocking licenses offline.
- Added Fixed Angle Shot for waypoint actions. Users can set the gimbal pitch, aircraft orientation, and camera zoom.
- Optimized the firmware compatibility of the remote controller to avoid abnormality caused by firmware downgrade.
- Optimized Payload SDK to provide more secondary development functions.
- Optimized some of the DJI Pilot 2 information such as prompts.
- Fixed known issues to improve user experience.
Notes:
Overview
- Date: 2023.06.26
- Aircraft Firmware: v07.00.01.02
- Remote Controller Firmware: v02.00.05.01
- DJI Pilot 2 App: V7.0.2.2
- DJI Assistant 2: v2.1.9
What’s New
- Added the remaining purchase service information for DJI FlightHub 2 in DJI Pilot 2.
Notes:
Overview:
- Date: 2023.03.02
- Aircraft Firmware: v06.01.06.06
- Remote Controller Firmware: v02.00.04.07
- DJI Pilot 2 App: V6.1.1.1
- DJI Assistant 2: v2.1.7
What's New?
- Added Terrain Follow for flight tasks:
a. Smart Oblique and Linear tasks support both Real-Time Follow and DSM Follow.
b. Oblique tasks only support DSM Follow.
- Added POI function. The aircraft can circle and fly around a PinPoint to obtain omnidirectional information of the target.
- Added ability to customize the camera angle for Mapping tasks. When planning a flight route, the aircraft orientation and gimbal pitch angle can be set for the route. Convenient for inspections of specific scenarios, such as solar panels.
- Added ability to execute flight tasks during flight for fast and efficient execution of flight tasks at the current location. Tap the flight route icon to create or select a flight task on the camera or map view of the DJI Pilot 2 app.
- Added ability to set Safe Takeoff Altitude for flight tasks to improve flight safety. This parameter setting is only valid when the aircraft executes a flight task before takeoff. If the aircraft starts a flight task during flight, the safe takeoff altitude will not take effect.
- Added ability to create Mapping or Oblique tasks by selecting an area in the map view. Convenient to generate a flight route after synchronizing the mapping area planned on DJI FlightHub 2 to the DJI Pilot 2 app.
- Added ability to import MBTiles format maps downloaded from Maptiler. The map layer can be customized in the DJI Pilot 2 app.
- Added ability to export logs by different modules in the DJI Pilot 2 app.
- Added encryption for Network Security Mode in the DJI Pilot 2 app. After setting a password, users can only change the Network Security Mode or adjust the function settings after entering the password.
- Optimized Real-Time Follow. The minimum altitude is adjusted from 80 m to 30 m. The altitude for Real-Time Follow is updated to 30-200 m.
- Optimized firmware update prompt in the DJI Pilot 2 app.
- Fixed issue: the aircraft returns too slowly if RTH is triggered from a short distance.
- Fixed issue: the RTH altitude is not updated timely on the DJI Pilot 2 app.
- Fixed rare issue: the aircraft vibrates when the aircraft orientation is adjusted during manual flight.
- Added ability for Mavic 3T to adjust infrared temperature measurement parameters, such as subject emissivity and temperature measurement distance.
Notes:
