DJI RS 2 Error code 1008
5707 4 2023-3-3
Daemon B
I am new to the RS 2 gimbal, and, in trying it with different cameras, I began to notice a problem with the gimbal drifting away from the neutral position after I'd puched the trigger button twice quickly. When I ran the gimbal auto-check, I received Error Code 1008.
Camera is balanced, and all axes are also balanced. It seems as if there are problems with the full rotation on the tilt axis.
Can I fix error code 1008?
2023-3-3
Daemon B
2023-3-3
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to follow the steps below and check if the issue persists?
1. Ensure that the camera load has already been mounted properly.
2. Ensure that the gimbal has been balanced.
3. Ensure that the gimbal Auto Check does not have interference.
4. Ensure that all axis locks are unlocked.
If the issue persists, please provide us with an operation video (video showing the issue) so we can check it here on our end. Please keep us posted. Thank you.
2023-3-3
LesterDieds
South Africa
Hi there
I had the same error 1008 on RS2 Pro Gimbal.
All I did was adjust the axis on which the camera is mounted. I just moved it up and tightened the lock.
Please try it, and if you need photos, I will post them as well.
2024-10-17
DJI Tony
LesterDieds Posted at 10-17 00:48
Hi there
Hi there. We are sorry for the inconvenience. Please first make sure that the camera is installed correctly, all three axes are unlocked, and the DJI Ronin single-handed gimbal is properly balanced.
Then please follow the below steps:
1.Ensure that the camera load has already been mounted properly.
2.Ensure that the gimbal has been balanced.
3.Ensure that the gimbal Auto Check does not have interference.
4.Ensure that all axis locks are unlocked.
2024-10-17
