DJI Paladin
Hi there. Thank you for reaching out. Hope that you could get the best recommendation from our fellow DJI Pilots here in Forum. If you are using the DJI RC, you may want to check the DJI Mic. Based on the preliminary test by DJI’s engineers, when inserting the DJI Mic receiver into the Host Port (USB-C) under the DJI RC, the DJI RC screen recording function can be used while recording the DJI Mic transmitter audio. After recording, remove the DJI Mic to play the video recording file with the audio. Hope this helps. Thank you for your continued support. |
