Lindos in Rhodes Greece
1251 17 2023-3-10
enikdem
Flight distance : 898520 ft
Greece
Still editing footafe from my christams holidays...
Question if anyone knows: On some capruters (not all) while editing when i increase the speed the result is not smooth like the original. Anyone knows the reason?
2023-3-10
Blériot53
Flight distance : 6188465 ft
Great views again. If I understand your question correctly, it may  be to to with the Bit rate (data transfer rate) that some computers or TV cannot keep up with.  Reducing this in post (in Davinci Resolve for example) or the resolution, may be a solution.
2023-3-10
DowntownRDB
Flight distance : 1722 ft
Enchantingly beautiful views.    Seeing the Acropolis of Lindos again was a nice bonus.
2023-3-10
Jake. A
Flight distance : 1205715 ft
2023-3-10
DAFlys
Beautiful footage.
2023-3-11
Depp
Flight distance : 1868796 ft
Increasing the speed will only look perfect when you go to 200 or 300 %, otherwise the system has to skip an uneven amount of frames to get it right. Say you put it to 120 % speed: Then one in five frames is skipped and that makes for jerky motion.Some editing softwares have special algorithms. In Final Cut Pro it's called "Optical Flow": The whole motion is analyzed and put back together.
It's even harder for the software to slow footage down. If you want good slow motion you should record in a higher frame rate. If your final product is supposed to be in 25 frames (typical for Europe) then if you recorded in 50 frames per second you can slow it down to 50 % (exactly 50%!) and it looks buttery smooth.
Nice place, by the way.
2023-3-11
enikdem
Greece
Blériot53 Posted at 3-10 11:12
Thank you.
2023-3-11
enikdem
Greece
DowntownRDB Posted at 3-10 12:27
Thanks, really a beautiful place to visit.
2023-3-11
enikdem
Greece
Thanks
2023-3-11
enikdem
Greece
DAFlys Posted at 3-11 01:21
Beautiful footage.
Thank you
2023-3-11
Blériot53
You're welcome
2023-3-11
enikdem
Greece
Depp Posted at 3-11 07:12
Hmm.. yes it has a logic, I will try.
But it does not happen to all the captures, this is what it puzzled me.
Thanks a lot for the explanation.
2023-3-11
DAFlys
Its my pleasure.
2023-3-12
Depp
enikdem Posted at 3-11 08:27
Might be in those takes that have less obvious movement that it's not as bad.
2023-3-12
DowntownRDB
enikdem Posted at 3-11 08:21
You're very welcome.
I hope to get back there again someday.
2023-3-12
Montfrooij
Flight distance : 2560453 ft
Very nice to see!
2023-3-13
Codgerzh2
Flight distance : 15567024 ft
Some nice footage
2023-8-14
enikdem
Greece
thank you,
2023-8-15
