Brocklll
DJI Paladin Posted at 3-12 19:11
Hi there. Thank you for reaching out. The DJI Mavic 3 supports the AF-C and AF-S. Please note that the focus mode is AF-C by default. You can tap the screen to switch the focus mode to AF-S duuring capturing. However, if capturing in AF-S for a period or target is changed, the focus mode will be changed to AF-C and cannot be set to AF-S again. Hope this helps. Thank you for your valued support.
Hi DJI Pladin,
thanks for your quick reply.
Unfortunately it is not reliably working as you described. If i do the tap-autofocus I had several examples, where the Mavic refocused e.g. for a tree that was passing close. this asbolutely ruined some of my shots, as the focus had to be on a building 50 meters away
And, it did not matter, if I did the tap focus while recording or before recording.
Please, why don´t your developers just bring back the af/afc toggle in the menu. would be so simple and soooo awesome. THANK YOU!!! |
