LV_Forestry
Flight distance : 4726654 ft
Latvia
Geo_Drone Posted at 3-23 23:13
After sales in EU is slow, in USA is fine.
From 15 x Evo2Pro, only 1 had issues in 3 years...is strong built...I cannot say the same on DJI, starting A2S I have exchanged every model at least 2 times in 6 months, the record is at Mini3Pro with 7 exchanges.
Main advantage is that the drone is built for mapping, all is optimized. Also the sensor quality is optimized for sharpness and low light.
I'm a bit puzzled by all the numbers you're posting. 3cm, 7 repairs...
The OP wants to make precision volumetric measurements. There is no miracle, you either need a drone with RTK/PPK, M3E or Autel with RTK receiver.
Or consumer drones with the possibility of planning mapping, so especially not the M3 for the moment, and you also need a maximum of GCP.
