dji assistant 2 calibration not working
2056 2 2023-3-15
David Thursfiel
Hi Good morning
I have managed to calibrate my Mavic Pro 2, probably once before. Trying again and still, I keep getting stuck on the 4/4 screen. Unable to calibrate. Yes, I have restarted everything at least twice. The battery is now dead and on charge. Any helpful advice would be gratefully appreciated.
David
2023-3-15
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Kindly please try to calibrate the said DJI drone using a monitor display of 14 inches or bigger is recommended for the calibration. Please set the display’s resolution to the recommended default value. ( Usually, the 14-inch display’s resolution should be set at 1366*768 or 1440*900. The 17-inch display’s resolution: 1366*768 or 1280*720. The 19-inch display’s resolution: 1366*768 or 1440*900. The 22-inch display’s resolution: 1680*1050 or 1920*1080. The 24-inch display’s resolution: 1920*1080 or 1920*1200.) Thank you.
2023-3-15
ECardella
Flight distance : 4771601 ft
I got a new drone and I was making sure everything was calibrated correctly, and I can't get the calibration to work.  I've uninstalled and re-installed.  I've tried different monitors/resolutions.  When the program is first installed, it asked for dimensions, I type in 1920, and the screen shows up, but in the bottom corner, it shows the sensors are x-ed out.  (I didn't get a screenshot of that).  I tried to esc out and retry, and I get stuck on this screen.
I was able to open and fly with the simulator.  I was also able to see that the sensors are working through the controller and the app, just not when connected to the computer.
2023-3-31
