Dji air 2s burnt
1343 5 2023-3-15
henry1cats
Flight distance : 1676020 ft
I would really like to find out what happened to this drone. This drone still turns on. Currently, I can't get it to connect to RC but it does connect to PC. The drone does do part of the self-test. I did do some testing and this is what I can tell. Some of the water indicators are red some are white. What looks like water damage on the main board. could be from the spider/ant/something that was living in it. but ecs was super clean so idk.
  • Working parts
gimbal, imu, bottom sen 1/2, back sen 1/2, leds
  • Unable to test
GPS, forward sen 1/2, up sen 1/2
  • Questionable parts.
main board, ESC, motors
I write this in hopes that someone smarter than me sees this and tells what happened to cause burning and why it still works, simply because I am curious.¯\_(ツ)_/¯
air 2s mid/gps
air 2s mid/gps
air 2s main
air 2s main
2023-3-15
Suren
Flight distance : 13498560 ft
New Zealand
Are those burns solely around the antennae areas?
2023-3-15
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we do apologize for the trouble that this has caused. I'm afraid that you may consider sending the unit in for a proper diagnosis. You may submit a ticket case at https://repair.dji.com/repair/index . Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. Thank you for your understanding and support.
2023-3-15
henry1cats
Suren Posted at 3-15 22:29
It was around 3 of the antennas and the chips next to them
2023-3-16
henry1cats
DJI Paladin Posted at 3-15 23:11
Is it possible for you to send me a new ecs, main board, and gps module? i can send my my faulty parts in return.
2023-3-16
DJI Paladin
henry1cats Posted at 3-16 05:23
Thank you for your request. Unfortunately, we don't sell or provide this type of drone parts. For us to proper diagnose and fix the issue, we highly recommend you send it to us. Thank you for your understanding and support.
2023-3-17
