dji rs3 pro.. wobbly, shaky, jittering (UNSATISFIED)
3312 6 2023-3-16
UNKNOWNDJI
I have been using the DJI RS3 PRO for approximately 4 to 5 months.
However, from the beginning, I was not satisfied with the outcome of the footages, as they were shaky and wobbly.
I searched for solutions online and tried everything from manual and autobalancing to tightening the axes, calibrating, restoring the settings, and using ninja steps to handle the gimbal and control the deadbands, but nothing worked.
As a result, I had to use the warp stabilizer to fix the shakiness of 70-80% of the footages during post-production.
I came across a YouTuber who had the same issue and made some content about it.
https://www.youtube.com/watch?v=Lt3cWdz-6s8&t=27s
The reason I am bringing up this issue now is because I saw the test footage of the Weebill 3, and the footage I captured with DJI RS3 PRO is incomparable to it.
Do any of you have the same or similar concerns about the stabilization of the DJI RS3 PRO?
I should visit to DJI store and compare with their gimbals to see if my one is defect..
2023-3-16
UNKNOWNDJI
here is the sample footage
https://www.youtube.com/watch?v=DvEqji9OG3g
They advertised : Laboratory sampling data shows RS 3 Pro provides a 20% increase in stability over RS 2, effortlessly managing low-angle shots, running scenarios, or switching between high and low positions.
No,, it's worse than RS2.
I am speaking with people in the other forums and they're having same experience!
2023-3-16
Vitor G.D.
Flight distance : 70499 ft
Brazil
UNKNOWNDJI Posted at 3-16 23:26
Sorry bro, but they're gonna ask you to do a lot of useless things that'll not work and finally they're gonna ask you to send it to repair, only for you to spend some time without the equipment before it gets back exactly the same or worse. They're not gonna do a recall. A lot of people are having this issue, same response from DJI, no solution.
2023-5-20
Property Pilots
Flight distance : 789836 ft
New Zealand
yeah me too. my Ronin-M was awesome, the Ronin S was pretty good especially in the DJI ring, but then the RS2 was the first with wobble, and now my RS3 Pro wobbles... plus I cannot balance the roll axis on the RS2 or RS3 and have the camera sit in any position. C70 or R5C  I also feel there is too much play in the pan head, like 1-2mm movement when switched off, and a little less in the roll head area. I've just changed my settings from slow to fast on the app, and its a bit stronger, but still yesterday had the wobble. its so enjoying as stabilising in Resolve or Premium Pro doesn't get rid of it.
2023-6-21
Vitor G.D.
Brazil
I regret leaving Zhiyun for DJI.
2023-7-26
MRZP
100% mine is doing that too. Shot a job and its unusable.
2023-12-14
diadempro
Oh crap, I found this thread hoping for a solution.  I have a real estate shoot in a couple days, was hoping this time I could capture the footage without the wobble.  No such luck, huh?
5-7 20:59
