spotlight does not track its object
1198 5 2023-3-16
Bernardo57Py
Flight distance : 3509183 ft
Paraguay
hey guys,
Spotlight doesn't want to follow its marked object.
Tracking FOLLOW and tracking PARALLEL works.
But with Spotlight, the drone doesn't fly after the object. However, the gimbal is directed upwards to follow the object.
What am I doing wrong?
2023-3-16
Mobilehomer
Flight distance : 18150351 ft
With spotlight, the drone centers on the object while you fly it.
2023-3-16
Sobrevolando Paraguay
Paraguay
I have made. But she doesn't fly. It doesn't track the object.
The gimbal will straighten up until the subject gets too far away.
2023-3-16
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Please note that Spotlight is different from ActiveTrack. Spotlight, as soon as you want to trace, the spotlight is enabled by default and the green box highlights the subject but as the subject moves, the drones stay put and the drone will not move like the ActiveTrack instead the gimbal locks the subject to its center position just like Mobilehomer mentioned on post #2. You can control the aircraft by manually moving the roll stick to circle the subject, moving the pitch stick to alter the distance from the subject, moving the throttle stick to change the altitude, and moving the pan stick to adjust the frame. You may refer to the tutorial link below and please start at @6:00. Hope this helps. Thank you.
2023-3-16
Paraguay
DJI Paladin Posted at 3-16 17:28
https://www.youtube.com/watch?v=6xY6IfcbBhI
Wow! I would like to thank you very much!!
Maybe it's because of my age... remembered this function differently.
So I don't need to do a total reset. A nice gift for the weekend.
2023-3-17
DJI Paladin
Sobrevolando Paraguay Posted at 3-17 03:36
It's always our pleasure to help. Should you have other inquiries, please don't hesitate to reach us. Thank you for your valued support!
2023-3-20
