DJI Mic Blitzschuhadapter
877 7 2023-3-17
JeLi64
Hallo,
also der beiliegende Blitzschuhadapter des DJI Mic rutscht auf einem SmallRigKäfig durch und bei meiner A6400 läßt er sich nur mit Kraft draufdrücken. Es wäre schön, wenn es da Alternativen gäbe.Bei Etsy hat einer etwas mit dem 3D Drucker gemacht (zum Schrrauben). Das kostet aber mit Versand fast 40 EUR
Jemand eine Idee?
2023-3-17
DJI Wanda
Hello, there. Sorry if I do not understand your issue correctly because I am trying to understand your issue with translation tools. May we know DJI MIC can not work properly on your camera due to the small rig block the adpater?
2023-3-19
JeLi64
Hello, the flash shoe adapter is too small or too thin and slips on the SmallRig cage and doesn't hold tight.
2023-3-19
DJI Wanda
JeLi64 Posted at 3-19 10:11
Can we have a photo to see how you put the adapter on the camera and the adapter you used? Thank you.
2023-3-20
HGDC84
Finland
I have a similar problem but with this adapter: https://www.amazon.co.uk/PGYTECH ... ount/dp/B07PN8N2JZ#
Somebody suggested putting some masking tape on the cold shoe adapter, but haven't tried yet if that works. I also have some rubber sticker which I could use to see if I can make it a better fit. But I'll see. I hope you get yours solved.
2023-3-20
JeLi64
DJI Wanda Posted at 3-20 02:59
Hello, how should I take a picture of a slipping hot shoe? I think it's self-explanatory that the photo shoe slips through. He's just too skinny. As the user HGDC84 already wrote, if you stick something under the photo shoe, then it no longer falls through. It doesn't matter which side you slide it onto the mount from.
2023-3-22
DJI Wanda
JeLi64 Posted at 3-22 01:24
Sorry for the inconvenience. It is too abstract for us to understand the issue.
We just want to like to check how you put the DJI MIC on the camera.
Even though I can understand your issue, I can not promise our engineers will comprehend what I was thinking. Thus, we would like to have a picture of the setup method.
Appreciate your understanding.
2023-3-22
HGDC84
Finland
Could a video clip be of use here? It could be possibly easier to demonstrate that way how loose the adapter could be, as you could show how easy it would be to bump it off.
2023-3-22
