Charge during record?
4855 1 2023-3-17
hohand27
Flight distance : 3215030 ft
Hungary
Hello!
I have an issue.
I have to make a timelapse around 5 hours of action with Action 2 camera.
Attached the power modul to the camera and I tried to charge it with powerbank, but when I start recording, the charging process stop.
The battery going to empty after 2,5hours.
Is there any solution for that?
2023-3-17
DJI Gamora
Hi, hohand27. Thank you for reaching out. When recording while simultaneously charging, the camera unit will no longer be charged. However, the power module/front touchscreen module will continue to be charged, so you can still use it. However, the heat from charging will affect the device’s battery life. It is recommended to power off DJI Action 2 and fully charge it before usage.
2023-3-17
