What is S1 switch?
2058 12 2015-8-21
marciano
Flight distance : 8748281 ft
Uruguay
From the Aug 11 Page 14 Manual Guide
"User cannot control the aircraft while the aircraft is ascending to its failsafe altitude. Howeverthe user can rapidly toggle S1 switch to regain control to cancel the ascending."
I know P1 and P2 S1 switch but P3
2015-8-21
jimcloud74
Flight distance : 1298317 ft
That is on the P3 Standard only. P3P and P3A have "return to home" button. Hope this helps.
2015-8-21
marciano
Uruguay
jimcloud74@yaho Posted at 2015-8-22 00:13
Ok, thanks.  This is in the professional user guide, DJI fault.
2015-8-21
jimcloud74
marciano Posted at 2015-8-22 04:31
No problem. I figured it was a typo in the manual.
2015-8-21
marciano
Uruguay
Page 41  "If you fly out of the limit, you can still control the Phantom 3, but cannot fly it any father. "
Ohhh, seems like I cannot take my father or yours for a ride by plane too far
2015-8-21
marciano
Uruguay
Page 43 No-fly Zone "If the aircraft enters the restricted area in A-mode, but is switched to P-mode, the aircraft will automatically descend, land, and stop its motors."
It will descend to the sea?
2015-8-21
marciano
Uruguay
Page 43 Note: Semi-automatic descent: All stick commands are available except the throttle stick command during the descent and landing process. Motors will stop automatically after landing.
There's no other mention about semi-automatic descent
2015-8-21
marciano
Uruguay
Page 45  When to Recalibrate
1.When compass data is abnormal and the Aircraft Status Indicator is blinking green and yellow.
2015-8-21
marciano
Uruguay
Page 51"How to safely operate the aircraft when encountering compass error?
A compass error may occur when the aircraft is flying close to strong electric magnetic sources (e.g. power transmission lines). Aircraft Status Indicators blink red and yellow rapidly when a compass error occurs and the DJI GO app will display one of the following messages:
• Compass error, calibration required
This warning message indicates the aircraft is receiving abnormal compass readings. It is recommended
to inflate a large air mattress, power off the aircraft and re-calibrate the compass at a different location and then resume the flight."
2015-8-21
marciano
Uruguay
Page 56
"*Home Lock and Point of Interest feature are coming soon."
Define "soon".  I've seen this notice months ago
2015-8-21
vr-pilot
Flight distance : 4668169 ft
marciano Posted at 2015-8-21 22:31
Just came across this line with "S1" switch instead of "Home" button in the P3pro user manual, too. It can be really confusing.
I have some experience with the Inspire1, so I knew that actually the P3pro "Home" button would interrupt ascending on RTH initiation. (Which is essential e.g. when you are just below trees and more than 20m away from your Home Point...)
So thanks to the forum for clearing this up.
2015-10-11
RATTYDUDE77
Flight distance : 2917 ft
make sure you have all salilites singles
2016-4-10
RedHotPoker
Flight distance : 165105 ft
Dude, you must be bored or lonely?
Why are you bringing back all these ancient papyrus scrolls? Hahaha
RedHotPoker
2016-4-10
