Sean-bumble-bee
Flight distance : 15997 ft
The Saint Posted at 3-20 09:14
yeah, a couple of post here confused me as well. it is my understand, dji care refresh and dji flyaway care coverage are not two separate things. there is only one form of insurance and it's called dji care refresh. there is a provision within dji care refresh and it's called dji flyaway care coverage. you can activate that coverage by binding your drone's account to your remote controller. this will record the linking relationship between your drone and the remote. you must bind (not pair, not connect, etc) the drone and the rc in order to make use of flyaway coverage and if you do not bind, you cannot make a flyaway claim after an incident even while your dji care refresh is in effect. but you can still make a non-flyaway claim for accidental damage; however, if you don't bind, the aircraft is automatically bound to the current log-in account.
i believe the op is asking about how many times he can pair and connect his remotes with different drones or the same drone. i could be wrong but in my mind, this is not actually "binding" the drone and the remote. you may pair, link/unlink, connect/disconnect your 2 different remotes with your m3p back and forth as often as you wish. apparently the same is true for binding/unbinding.
Ditto.
you can activate that coverage by binding your drone's account to your remote controller. Strictly speaking I don't think that is correct, isn't there an additional fee/premium that must be paid first, which is over and above the ''Care Refresh'' premium?
I'd delete the words ''linking relationship'' and substitue ''association'', so as to avoid using the word ''link'' or a derivative of it, when talking about 'binding'.
if you do not bind, ........ but you can still make a non-flyaway claim for accidental damage
QUESTIONABLE and the point of my post #3, which has yet to be answered by DJI Paladin.
IS IT?
I do not believe he is asking about ''pairing'', which I take to mean the establishing of the connection between the drone and the controller for control purposes, to me he appears to say that that is quite easy.
I believe he asking if there is a limit to the number of times he can bind and unbind controllers to and from the drone, where '' bind'' etc. refers to connect between the drone and controller that is required for the FlyAway cover to be vaild.
