DJI RS3 Pro defect - internal cable too short ?
1529 1 2023-3-20
JBSonic
Flight distance : 1050335 ft
Hi,
I have the DJI RS3 Pro (bought August 2022).
It works ok but there is an issue which so far has not been a problem but it clearly is a manufacturing fault.
The Roll Axis arm is unable to extend to its full length because the cable inside is too short.
See pictures:
This is as far as that arm can extent due to the cable being too short
Notice internal cable
Notice the black cable inside, this is as far as the arm can extend and the cable is stopping it from going any further.
Dji moderators, please could you advice on how to fix this issue, I  guess I have to send the RS3 Pro to you for repair/replacement.
Thank you.
2023-3-20
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the unpleasant experience. I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support . Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. Thank you for your kind and understanding.
2023-3-20
