mortenzokan
Norway
Labroides Posted at 3-22 03:33
it seems like only way my mini 2 sets those parametres is if i use panorama mode.
Every still image you shoot with the drone will have that information in the metadata.
Post an original, full-sized jpg (you'd have to upload to dropbox or something like that and post a link), and I'll show you.
Hi, sorry late answer here. This is metadata from a image definitly take with tilted camera. (I can even view the flight logs and see that gimbal angel IS not 0 in this example). (I'm not using more time on this, since i understant it is not important for photogrametry, but strange thing anyway ) And thanks for help
ExifTool Version Number : 12.58
File Name : DJI_0246.JPG
Directory : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
File Size : 5.3 MB
Zone Identifier : Exists
File Modification Date/Time : 2023:03:23 13:31:11+01:00
File Access Date/Time : 2023:03:27 19:43:56+02:00
File Creation Date/Time : 2023:03:23 12:30:00+01:00
File Permissions : -rw-rw-rw-
File Type : JPEG
File Type Extension : jpg
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Image Description : DCIM\100MEDIA\DJI_0246.JPG
Camera Model Name : FC7303
Orientation : Horizontal (normal)
X Resolution : 72
Y Resolution : 72
Resolution Unit : inches
Software : v01.43.0071
Modify Date : 2023:03:23 12:43:57
Y Cb Cr Positioning : Centered
Exposure Time : 1/50
F Number : 2.8
Exposure Program : Program AE
ISO : 100
Exif Version : 0230
Date/Time Original : 2023:03:23 12:43:56
Create Date : 2023:03:23 12:43:56
Components Configuration : Y, Cb, Cr, -
Compressed Bits Per Pixel : 3.350436
Shutter Speed Value : 1/50
Aperture Value : 2.8
Exposure Compensation : 0
Max Aperture Value : 2.8
Subject Distance : 0 m
Metering Mode : Spot
Light Source : Daylight
Flash : No flash function
Focal Length : 4.5 mm
Warning : [minor] Possibly incorrect maker notes offsets (fix by 1783?)
Make : DJI
Speed X : +0.00
Speed Y : +0.00
Speed Z : +0.00
Pitch : -1.20
Yaw : +125.50
Roll : +0.50
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 4000
Exif Image Height : 3000
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Exposure Index : undef
File Source : Digital Camera
Scene Type : Directly photographed
Custom Rendered : Normal
Exposure Mode : Auto
White Balance : Auto
Digital Zoom Ratio : 1
Focal Length In 35mm Format : 24 mm
Scene Capture Type : Standard
Gain Control : None
Contrast : Normal
Saturation : Normal
Sharpness : Normal
Subject Distance Range : Unknown
Serial Number : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
GPS Version ID : 2.3.0.0
GPS Latitude Ref : North
GPS Longitude Ref : East
GPS Altitude Ref : Above Sea Level
XP Comment : Type=N, Mode=P, DE=None
XP Keywords : v01.43.0071;0.0.1;v1.0.0
Compression : JPEG (old-style)
Thumbnail Offset : 18432
Thumbnail Length : 9716
About : DJI Meta Data
Format : image/jpg
Absolute Altitude : +289.85
Relative Altitude : +5.90
Gimbal Roll Degree : +0.00
Gimbal Yaw Degree : +0.00
Gimbal Pitch Degree : +0.00
Flight Roll Degree : +0.50
Flight Yaw Degree : +125.50
Flight Pitch Degree : -1.20
Cam Reverse : 0
Gimbal Reverse : 0
Version : 7.0
Has Settings : False
Has Crop : False
Already Applied : False
MPF Version : 0010
Number Of Images : 2
MP Image Flags : Dependent child image
MP Image Format : JPEG
MP Image Type : Large Thumbnail (VGA equivalent)
MP Image Length : 260596
MP Image Start : 5062138
Dependent Image 1 Entry Number : 0
Dependent Image 2 Entry Number : 0
Image UID List : (Binary data 66 bytes, use -b option to extract)
Total Frames : 1
Image Width : 4000
Image Height : 3000
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Aperture : 2.8
Image Size : 4000x3000
Megapixels : 12.0
Scale Factor To 35 mm Equivalent: 5.3
Shutter Speed : 1/50
Thumbnail Image : (Binary data 9716 bytes, use -b option to extract)
GPS Altitude : 289.8 m Above Sea Level
GPS Latitude : 59 deg 55' 56.10" N
GPS Longitude : 10 deg 46' 47.28" E
Preview Image : (Binary data 260596 bytes, use -b option to extract)
Circle Of Confusion : 0.006 mm
Field Of View : 73.7 deg
Focal Length : 4.5 mm (35 mm equivalent: 24.0 mm)
GPS Position : 59 deg 55' 56.10" N, 10 deg 46' 47.28" E
Hyperfocal Distance : 1.28 m
Light Value : 8.6
-- press ENTER -- |
