DJI Paladin
Hi there. We apologize for the inconvenience. The maximum flight time of 31 minutes claimed on the DJI official website is measured when the aircraft is flying at 5.4 m/s in windless conditions (25°C) from taking off with a full battery level to the time when the aircraft triggers a low battery warning and automatically lands on the ground. However, during the actual flight, due to environmental limitations (temperature, wind power, and air pressure), aircraft speed, and other factors, the maximum flight time may be decreased to different levels.
Reason for environmental factors affecting the maximum flight time:
Temperature: In a low-temperature environment, the battery’s discharging performance becomes weaker, which will shorten the maximum flight time. A high-temperature environment will affect the cell endurance. When the aircraft is used frequently in a high-temperature environment, the maximum flight time will be affected, and the cell is likely to be damaged.
Wind power: In a windy environment, the aircraft needs to increase the power for wind resistance. As such, the motor output power is increased, the load current is increased, and the battery level consumption is increased.
Air pressure: (The air pressure in the test environment is similar to the air pressure value at sea level.) The air pressure is low in the high altitude area, and thin air causes higher motor load and load current, which results in greater power consumption.
