DJI Paladin
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Please try the troubleshooting steps below and see if the issue persists.
If you are using a Windows PC:
DJI Assistant 2 can be modified to achieve the upgrade. Please check the below steps:
1. Please download the DJI Assistant 2 (https://www.dji.com/downloads/so ... sumer-drones-series) from the DJI Website;
a. Turn on the aircraft and connect the aircraft to the computer within 10 seconds using the data cable.
If you connect the computer to the aircraft after 10 seconds, the computer will not be able to recognize the aircraft.
2. Program Files (x86) > DJI Product > DJI Assistant 2 (Consumer Drones) > DJI Engine > , find "defaultsettings.ini", then open it and change the "0" to "1".
