Newbie cannot get Assistant 2 simulation to work
1417 6 2023-3-22
j13
South Africa
I am a Newbie to Drones and want to try a simulation before flying.
DJI Mini 2 (V01.06.0200)+ RC231 (RC-N1) 04.11.0200
Huawei P9 lite  -  DJI FLY  1.9.4
Dell E7450 laptop i5 8GB
Windows 10 Pro V 22H2  os build 19045.2728
DJI Assistant 2 (consumer drones) V2.1.16
Safety data 01.00.01.29
Brand new drone, never flown, tried for 6 hours to use simulation.
Can connect phone-controller-drone
or Drone-dji Assistant 2
But not phone-controller-drone - Assistant 2
start sequence: [phone ON , laptop ON, propellers off]
open Assistant 2 on laptop
cable controller to phone
open DJI fly App
cable Drone to Laptop
turn contoller ON
turn drone ON
Also tried turning drone ON before controller. This shows Drone on Assistant 2
with options to update, Log Export & DJI Assistant Log. Not calibration. Not Simulation
Device manager then shows Ports: DJI USB Virtual COM (COM8)
DJI Fly shows Unable to take off> Disconnect aircraft from USB (Code: 30254)
Disconnect USB from Drone, DJI Fly 'Take off with caution'
Reconnect Drone to laptop with USB , Drone shows on Assistant , but DJI fly won't connect to Drone until laptop disconnected….
Any ideas?
2023-3-22
DJI Gamora
Hi, j13. Thank you for reaching out. Are you trying to use DJI Assistant 2 as a Flight Simulator? Regretfully, DJI Assistant 2 for Mini 2 doesn't have that kind of feature. You won't be able to see calibration options as well since DJI Mini 2 doesn't have any vision sensor to be calibrated (it only consists of a downward vision system).  The DJI Assistant 2 for Mini 2 supports exporting flight data and firmware upgrades only. Hope this helps. Thank you for your support.
2023-3-22
Fly12
Romania
DJI Gamora Posted at 3-22 20:54
Hi all, any updates since march2022? Is there any way to use DJI Assistant 2 flight simulator with DJI Mini 2 drone?
2023-4-7
dnddad324
Flight distance : 12536706 ft
DJI Assistant nu este un simulator de zbor. Este un program de gestionare a firmware-ului.
DJI Virtual Flight este un simulator, dar funcționează numai cu drona DJI FPV și DJI Avata.
DJI nu are planuri pentru un simulator pentru seria Mini.
2023-4-7
DJI Gamora
Fly12 Posted at 4-7 08:01
Hi, Fly12. DJI Assistant 2 for Mini 2 cannot be used as a simulator. The main use of the DJI Assistant 2 for this drone is to utilize firmware updates. Regretfully, there's no current simulator compatible with DJI Mini 2. We're sorry for the inconvenience.
2023-4-9
djiuser_5h7RooD9cl6g
Latvia
My DJI Mini 2 is giving me  a server error code 0x1103a0090012
2023-4-9
SnitserNL
Flight distance : 2372014 ft
djiuser_5h7RooD9cl6g Posted at 4-9 08:21
Try again after disabling your firewall during the use of DJI Assistant 2.
2023-4-10
