No Original Thought
Flight distance : 1364209 ft
MetaFlexa Posted at 3-25 22:17
Here you can see what I am talking about. If I want it to be proper vertical (portrait mode) then I must crop…[Image]
What resolution are your vertical images and what resolution are your horizontal images?
In this second screen shot you have black all around the image, in your previous screenshot you only have black at the sides. This implies that the black is not part of the image and therefore cannot be dropped of the image. The black areas are just because the image has a lower resolution that the display you are viewing it on. The extra screen space either needs to be filled with something (in this case black) as there is not enough image to fill the screen, or you need to zoom in - in which case on a horizontal monitor you will still have black at the sides because a vertical picture, by definition, cannot fill a horizontal monitor. |
