Securing DJI mic to Action 3
4321 26 2023-3-27
Deebee941
Has anyone come up with a way to secure the DJI wireless mic to the Action 3? I want to use the wireless mic attached to the Action 3 for motor vlogging. The action 3 with the attached wireless receiver can happily sit on the front of my motorcycle helmet but I want to ensure that the receiver doesn’t fall off. Apart from an elastic band, any ideas?
2023-3-27
johansenfoto
Flight distance : 1180089 ft
Norway
Just and idea, I have actually bought this for securing cameras when needed
https://www.ebay.co.uk/itm/334479787904
2023-3-27
Deebee941
johansenfoto Posted at 3-27 08:44
That works for the camera but not for the mic receiver. Essentially it is a box that plugs into the side of the camera. There is nothing to secure the lead to, unfortunately.
2023-3-27
Fishycomics
does the Rx have a clip, if so buy a cage that has a cold shoe
2023-3-27
Deebee941
Fishycomics Posted at 3-27 11:03
The only way the mic can attach to the actual camera is via the usb connector. There is no clip or anything else to attach to a cold shoe.
2023-3-27
Fishycomics
so this is not the dji wireless mic you got
2023-3-27
Deebee941
Fishycomics Posted at 3-27 11:30
[view_image]
It appears that what I don’t have is the shoe adapter!
2023-3-27
Deebee941
I only bought the single transmitter and receiver.
2023-3-27
Fishycomics
thank you,   always a way to do things,  if a clip  can be had I glue one on, run a cable, something you are going to have to think about doing
2023-3-27
Deebee941
Fishycomics Posted at 3-27 12:18
It looks like that is what I will have to do.
2023-3-27
lutzmix
you have a cold shoe adapter in your set
min 1'50"
YhDt5a3i1SA
min6. Etsy basement creator
2023-3-27
Deebee941
No I don’t. I only bought the one transmitter with the receiver.
2023-3-27
Deebee941
Plus the plan is to have the camera fitted to a chin mount on a motorbike helmet. Not too keen on a case with a cold shoe on top as I think it is going to obstruct my vision.
2023-3-27
Deebee941
Will double check to see if I missed the shoe mount. Thanks for that.
2023-3-27
Fishycomics
well buy a cold show and glue to   anywhere like. I say
2023-3-27
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Hope that you could get the best recommendation from our fellow DJI members that currently have this setup. Should you have other inquiries or concerns about the product, please don't hesitate to reach us. Thank you for your valued support.
2023-3-27
lutzmix
try your usbc connector with a rubber ring .iff you have space use foam rubber between camera and receiver .
i have no problems with my mono receiver
ulanzi and smallrig.no problems without an extra safty ring
rubber rings from  flower shop greengrocer are verry strong
2023-3-27
Fishycomics
allow some time.  I show what may be best for you, but you decide, and @Lutzmix credit to him, on his band idea, take it one step further, with what I show, if like be a little less stressful if asked on the  ports
https://youtu.be/C7fMcgC3Fi8
2023-3-28
Fishycomics
2023-3-28
Deebee941
I thought it might come down to elastic bands. Seems to be the obvious, cheapest and most reasonable solution. Thanks for that.
2023-3-28
johansenfoto
Norway
Fishycomics Posted at 3-28 04:26
Would also choose the glue option
2023-3-28
lutzmix
magnet mount
2023-3-28
lutzmix
minimalistic and save (only mono)
best price 50€
2023-3-28
Fishycomics
You have a number of Options to choose from    see photo writing or video
2023-3-28
4wd
Flight distance : 545817 ft
Deebee941 Posted at 3-27 11:22
You can connect the RX unit to camera with a USB-C male to USB-C male data cable.
Using the charging input not the sticking out attachment.
So you aren't obliged to have it directly plugged in.
The RX unit can be clipped into a cold shoe mount and these can be bought in various forms which might be inventively attached to helmet or something.
2023-3-28
lutzmix
Ulanzi 0A-19 cold shoe
2023-5-19
MartinBG
Flight distance : 282044 ft
Bulgaria
I am facing the same problem - no secure way to attach DJI Mic to Osmo Action 3 when using the setup on a bike or other activities with more action.
Using the mic directly attached to the USB-C port is out of question as it will either fall off or will damage the port at some point because of mic weight and vibrations. Wrapping it with rubber straps as in the video above could improve the situation for sure, but is not a perfect solution either.
As I am using the SmallRig camera cage I tried to mount the mic receiver to the cold shoe mount on top of the camera and then using a USB-C to USB-C cable to connect the receiver to the action camera. That setup puts less stress on both USB ports, but the receiver was not stable there because the cold shoe adapter for the mic from DJI is with very poor design and cannot hold the mic to the attachment point. I could probably use rubber straps or similar workaround for that problem, but maybe a safer solution for this particular use case (bike mount) would be to just keep the receiver in a bag on the bike frame and use a cable to connect it to the camera.
In any case it is very disappointing that DJI failed to provide a solution for connecting their action camera and mic which is applicable for at least some of the action sports (XC biking in my case).
2023-5-30
