Speed switch defaults to N
442 3 2023-3-27
Richinwalla
On my RC I have the speed switch set to Cinema, but the display says I'm in N (Normal).  To get Cinema, I have to set the switch to Normal and then back to Cinema.  Is this the way it is supposed to work?
2023-3-27
DAFlys
Yes,   the drone will always take off in Normal (N) mode.  It's by design.
2023-3-28
DJI Wanda
Hello, there. By default, the Mavic series drone will power on in Normal mode (N-mode) regardless of the remote controller mode. After powering on, switch the remote controller mode again, the aircraft flight mode and the remote controller setting mode will be consistent.
2023-3-28
Jake. A
Flight distance : 1205715 ft
Yep, that happens all the time. just the way it works.
2023-3-28
