Mavic 3 sensor problem/ "preparing to take off" message
870 7 2023-3-27
Yusaku
Greece
When in flight, after some minutes (usually when battery is around 50%), I get the message "preparing to take off" and then the sensors stop from working. This message comes after the latest update. Before that I had the same problem (sensors stopped working while flying) with a different message. The message was "vision system error".
Did anyone had the same problem? What do you propose as a solution?
Thank you
Kostas
2023-3-27
DJI Wanda
Hello, there. Sorry for the inconvenience. May we know did you crash the aircraft before or did you check the sensors?
2023-3-28
Yusaku
Greece
DJI Wanda Posted at 3-28 00:08
Thanks for the swift reply.
I did not crash the aircraft and yes, I have checked the sensors.
2023-3-28
DJI Wanda
Yusaku Posted at 3-28 05:21
Did you record any videos about the issue before?
Is it convenient to you to share the video?
2023-3-29
Yusaku
Greece
DJI Wanda Posted at 3-29 04:26
Please find attached a video recorded when the problem appears.
After the message "preparing to take off..." the sensors stop from working.
sensor problem1.rar
770.99 KB, Down times: 2
2023-4-3
DJI Wanda
Yusaku Posted at 4-3 02:45
Sorry for the late response. May we confirm more details with you?
Does this issue occur on each flight?
Will this message disappear at a certain point? If so, may we know more information?
2023-4-3
Yusaku
Greece
Yes, this message occurs in every flight and unfortunately, no, the message does not disappear. I have to land the drone and restart it in order to disappear.
Although I am not using the drone for videos, in my only time I spent a battery recording a video in cine mode, the message did not appeared.
2023-4-4
DJI Wanda
Yusaku Posted at 4-4 02:10
In your case, we will recommend you send it back for further diagnosis.
Here is the link to submit online repair request: https://repair.dji.com/us/repair/index
2023-4-5
