DJI Support
Flight distance : 2408 ft
Overview:
- Date: 2023.04.25
- DJI Goggles Integra Firmware: v01.02.0000
- DJI Fly App Version: v1.10.0 (iOS & Android)
What’s New
Added support for the following products:- DJI Mavic 3 Pro (including DJI Mavic 3 Pro Cine)
- DJI Mavic 3 (including DJI Mavic 3 Cine)
- DJI Mavic 3 ClassicDJI
- Mini 3 Pro
Notes:
- Update the firmware of the aircraft, goggles, and motion controller before using for the first time, otherwise the devices cannot be linked.
Aircraft: Update the firmware using the original remote controller of the aircraft.
Goggles and motion controller: Connect the goggles to a mobile device and run the DJI Fly app. Select ProfileàDevice Management. Locate the corresponding goggles. Select Firmware Update and follow the on-screen instructions to update the firmware.
Alternatively, the DJI Assistant 2 (Consumer Drone Series) software can be used on a computer to update the firmware of the devices separately.
- When the above aircraft are used with the goggles, only DJI RC Motion 2 is supported for flight control, other remote controllers cannot be used to control the aircraft.
- Restart the aircraft, goggles, and motion controller after the firmware update is complete.
- Note that the update may reset various flight parameters such as the RTH altitude and the maximum flight distance. Before updating, take note of your preferred settings and readjust them after the update.
- If the update fails, restart the devices and software, and then try again.
Overview:
- Date: 2023.03.28
- DJI Goggles Integra Firmware: V01.01.0000
- DJI RC Motion 2 Firmware: v01.01.0000
- DJI Avata Firmware: v01.03.0000
- DJI FPV Remote Controller 2 Firmware: v02.00.0600
- DJI Motion Controller Firmware: v02.00.0600
- DJI O3 Air Unit Firmware: v01.02.0000
- DJI FPV Air Unit Module Firmware: v01.01.0000
- DJI Fly App Version: v1.9.8 (iOS & Android)
What’s New?
- Added support to use with DJI FPV Air Unit Module.
- Added functionality to erase all user data generated and stored on the aircraft during flight when used with DJI Avata. To use the function, open the goggles menu and select Settings>About>Clear All Data.
- When used with DJI Avata, RTH altitude prompt was added after updating the Home Point.
- When used with DJI Avata, the low battery RTH countdown was increased to 15 seconds.
- Added support for Betaflight 4.4 HD OSD when used with DJI O3 Air Unit or DJI FPV Air Unit Module.
- Optimized the visual prompts when remote control or image transmission signals are weak.
Notes:
- Restart the aircraft (or air unit), remote controller, and goggles after the update is complete.
- If update fails, restart the aircraft (or air unit), remote controller, goggles, and DJI Fly or DJI Assistant 2 (Consumer Drones Series) and try again.
