Canvas Mode is compatible with Betaflight 4.4.0 and later
2109 0 2023-3-28
Jonatan.N
Flight distance : 170627 ft
Canvas Mode is compatible with Betaflight 4.4.0 and later.
1.Hardware Connection: connect the UART RX of the air unit to one of the UART TX serial ports (takeUART4 as an example) of the flight control board.
2.Configuring UART: open the Betaflight Configurator software and select Ports. Turn on the MSFswitch for the corresponding UART TX serial port (UART4) and set baud rate to 115200. Peripherals set to" MSP+Displayport "  Click  Saveand Reboot.
3.Configuring CLl:
Select CLI from the Betaflight Configurator software and make the following configuration::
set osd_displayport_device = MSP
Save and exit:
Canvas Mode initial setup is complete.
OSD display and settings before modification
After upgrading Betaflight 4.4, it is necessary to adjust the OSD setting interface to HD.
After making adjustments, don't forget to click "Save Settings". Now let's see how to set the glasses end.
Video: https://www.skypixel.com/videos/betaflight-4-4-0
2023-3-28
