Firmware update not effective
859 10 2023-3-29
mgoimarac
Flight distance : 1485036 ft
I updated my mini 3 pro to aircraft firmware version 1.00.0500, but when I check the options in "Gain and Expo Tuning" I do not have the new horizontal and vertical speed controls.  Any suggestions.
2023-3-29
DowntownRDB
Flight distance : 1722 ft
Did you also update to Fly App v 1.9.8?  If not, that is why you aren't seeing it.
2023-3-29
mgoimarac
DowntownRDB Posted at 3-29 12:42
I have version 1.9.4, but when I go into settings on my remote and try to update the firmware, it says my firmware is up to date.  So how do I get my remote updated to 1.9.8?
2023-3-29
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please confirm if you are using the DJI RC-N1 (standard RC with a mobile device) or the DJI RC (built-in screen), if you are using the DJI RC,  please try to download the DJI Assistant 2 software on your computer and please update the DJI RC to the most latest firmware v01.02.0500 and check if the RC has now the DJI Fly app v1.9.8? You may download the correct version of the software using the link below. Please keep us posted. Thank you.
https://www.dji.com/downloads/so ... sumer-drones-series
2023-3-29
fansf75fe932
I downloaded the DJI Assistant 2, connected to my remote and went to firmware upgrades.  However, the most recent available upgrade was V01.02.0400.  There was no V01.02.0500 version.  I tried refreshing with the V01.02.0400 version thinking that it would make my device search for a newer version, but it did't work.  My device still says I am running App version 1.9.4.  Please advise.
2023-3-29
DAFlys
They just released V01.02.0600,  seems the 0500 update called pulled early.
2023-3-30
DJI Paladin
fansf75fe932 Posted at 3-29 19:24
Sorry for the trouble. Can you please try to connect again and check if you can now update to the latest version v01.02.0600? Your DJI Fly app should be v1.9.9. Please keep us posted. Thank you.
2023-3-30
DowntownRDB
mgoimarac Posted at 3-29 16:24
Appears there were issues with 1.9.8 so it was pulled.  You should now be able to update and it will be version 1.9.9.
2023-3-30
Blériot53
Flight distance : 6188465 ft
These are the latest updates you should be on:
Aircraft firmware 01.00.0500
RC firmware  01.02.0600
App version 1.9.9
They are all available now.
2023-3-30
fansf75fe932
I tried to download the latest firmware version 1.02.0600.  All was going good until it got to the update portion and then it froze at 7%.  I tried to start over, but when I did DJI Assistant 2 gave me no options for firmware upgrades.  It just stuck on "loading".  Please advise
2023-3-30
fansf75fe932
As a further update.  I went into the  menu of my RC controller after the incomplete update, and it said that the controller had been updated to Version 1.9.9.  So I decided to try it out.  Things worked ok, except when I changed the gain and expo tuning to slow down the drone in cine mode, it had no effect even though I set them to the slowest settings.  So now I have a drone and controller that thinks they have been updated, but in fact they haven't.  Please advise.
2023-3-30
