Alien tech
Flight distance : 84902 ft
Bulgaria
Been checking it out, and the bucket will work, the size and mailability of the plastic needed can be, shall I say adjusted/bent justa little! Your sort of right about the ideal distance, between antenna, and reflector, but ( too a point) the angel of the curve is not so important! What determines the make or break of a good working system, in this case anyway, is the the distance between, antenna, and reflector, so there is some leeway or adjustment. The shallower the curve the further away the antenna needs to be in front of it , This only happens due to it being a transceiver, if it was only one or the other this would be quite different. Its not that precise any , as there is a guy who demonstrates the effectiveness, of one he makes out of paper, and tin foil of course, and it works very effectively. May not be quite as good as the pro versions, but he is getting 90+% of the extra range they are, for pennies opposed to 30 to 50$ a saving that's worth saving, and its a bit of fun to do anyway, cutting buckets up, ahhah. Reminds me school. |
