spheasant1
Flight distance : 3014675 ft
Couple questions:
1) I'm assuming you have the firmware file on your microSD card, you plug that into your Phantom, and then you just turn on the phantom and let it update...correct?
2) Serializer is most likely the communication path from your phantom to your camera.....check your cables on the phantom that connect the camera/gimbal and make sure they aren't loose and potentially disconnected. |
