Do Goggles V2 need 2.4 GHz antennas to work properly with DJI Avata?
1239 4 2023-3-30
PioHosT
Flight distance : 275197 ft
Poland
My question: Do Goggles V2 need 2.4 GHz antennas to work properly with DJI Avata? (currently I am using Crystal HD 5.8Ghz patch and stubby antennas)
Avata in 2.4GHz is RX only.
My suspicions:
Probably yes, camera settings, rth settings etc. are sent on 2.4GHz from the goggles to Avata.
Can anyone confirm this?
2023-3-30
DJI Gamora
Hi, PioHosT. Thank you for reaching out. When the DJI Avata image transmission frequency is in automatic mode, DJI Avata can automatically switch between 2.4 GHz and 5.8 GHz when receiving signals during flight. The transmission signal only uses 5.8 GHz, which cannot be used in some countries that restrict 5.8 GHz.
In Manual mode, the default frequency is 5.8G, which cannot be switched.
Hope this helps.
2023-3-30
PioHosT
Poland
DJI Gamora Posted at 3-30 19:12
Hi DJI Gamora,
Are you sure?
From DJI AVATA specs https://www.dji.com/pl/avata/specs :
Video Transmission
Communication Frequency
2.400-2.4835 GHz (RX only)
5.725-5.850 GHz (RX and TX) [4]
2023-3-31
DJI Gamora
PioHosT Posted at 3-31 05:16
Hi DJI Gamora,
Are you sure?
Hi, PioHosT. Since you are using a 3rd party accessory that] is not tested, we won't be able to confirm this. Please use the supported goggles to verify if it is working correctly. Thank you for your kind understanding.
2023-4-2
Snoze
Flight distance : 7832014 ft
PioHosT, you have signal improvement with iflight patch vs stock antenna with the Avata?
3-21 12:51
