JJB*
Flight distance : 12401030 ft
No problem Labroides,
Hope you can understand my text and chart, chart now with the values for the X and Y speed component.
Drone in Autolanding, so distance in the log to HomePoint is zero or almost zero, normally.
In this log AutoLandoing startet at height 227 meter, distance to home 0.1 meter.
At 6m51.0 sec IR height started to measure again, height 7.7 meter. Downspeed 2.8 m/s.
Distance to HP still 0.1.
At 6m53.6 at 0.2 height down speed minus 0.3, distance to home 0.1 meter.
So drone came down in a perfect on the spot to the ground....no lateral (left/right/fwd/aft) moves in there.
Check drone Pitch and Roll angles and X Y speed, see my chart with the X Y speeds.
Next record IR height 0.0 meter, at this very moment the X speed component from zero to -0.6.
In this record also drone pitch attiude change from to 26.2 degrees, in green = pitching down = forward move (as in the video).
This is also seen as distance to HP is increased the moment height is zero. As the bottom sensor is very accurate, zero in the log is zero = touching the ground.
So all this make me think, with the text of the operator, that drone indeed descende to fast, 'hit; the ground and moved bit forward.
Normal in an oke descent the cam is automatically from down to zero pitch before last part of landing is executed. As you can see in the video and in the log ; drone almost landed, sign of going too fast in the autolanding last part. Beacuse of this cam move to zero it looks likes the drone moves forward earlier...
But no problem if we have a different analysis, always nice to read the thoughts of others on here.
cheers
JJB
