Horisontal lines on DNG images
3579 27 2023-4-1
Bo Christensen
Flight distance : 190554 ft
Denmark
Hi
Just expirenced a wierd problem when shooting DNG (RAW) images on my DJI Mini Pro 3.
I have tried formatting the SD card, and swapping it for a new one, same issue.
The JPG images is fine, only the DNG are displaying these horisontal lines.
Anybody has a clue about whats wrong?
Thanks in advance.
Best regards
Bo Christensen
Lines
Lines
2023-4-1
DJI Wanda
Hello, there. Sorry for the inconvenience. May we know did you check the picture on different software? If so, please change a new SD card and shoot a new DNG picture. Then, do not open it and send it to us for further verify the issue. Thanks in advance.
2023-4-1
Bo Christensen
Denmark
HI
I have made some images/video to test the issue som more (all made from the same static view) :
As stated earlier, I have already both formatted/reformatted and exchanged the SD card.
DJI_0001 is a 4K/30 30 second video :
https://www.dropbox.com/s/w7ka3y6lkbez578/DJI_0001.MP4?dl=0
DJI_0002 is images shot I standard resolution :
https://www.dropbox.com/s/c1gsvio6ovyua44/DJI_0002.DNG?dl=0
?dl=0
https://www.dropbox.com/s/ako5j8x1xmct4lq/DJI_0002.JPG?dl=0
DJI_0003 is images shot I 49MP resolution :
https://www.dropbox.com/s/fahiimmbtzkk7dc/DJI_0003.DNG?dl=0
?dl=0
https://www.dropbox.com/s/9hx0qhlbthdwd4u/DJI_0003.JPG?dl=0
DJI_0004 is only JPG shot in 48MP resolution :
https://www.dropbox.com/s/4v4yz6e40bslgtx/DJI_0004.JPG?dl=0
DJI_0005 is images shot I 48MP of a white wall :
https://www.dropbox.com/s/qecw50iemqzcwaq/DJI_0005.DNG?dl=0
?dl=0
Hope this helps in trouble shooting the issue?
Best regards
Bo Christensen
2023-4-2
DJI Wanda
Bo Christensen Posted at 4-2 00:07
HI
Thank you. We will escalate your issue to our engineers and let them check your issue.
2023-4-2
Bo Christensen
Denmark
Hi
Okay this is weird.. and getting weirder... can you please confirm that you see the lines on any of the DNG I shared with you?
Just looked at an older foto, taken from the drone, and it has the same lines.
Best regards
Bo Christensen
2023-4-2
Bo Christensen
Denmark
Hi
Ok.. so did a little testing myself on the images.
If I open the DNG file on a macOS Catalina it is fine, but if I open the same image on another Mac running macOS Ventura (13.3), I get the striped issue.
See picture below.
Stripes
Stripes
2023-4-2
Bo Christensen
Denmark
Hi
This is definitely a macOS related problem, og not DJI related in any way.
If I convert the DNG image with Adobe Digital Negative Converter, and use a profile of Camera Raw 4.6 or an older version, the images is fixed.
If I use a newer Camera Raw profile, the problem is the same.
After converting I can now edit them in Pixelmator Pro without any artifacts (or stripes).
So the problem relates to an issue in macOS Ventura 13.3, or another DNG componet within the operating system.
See picture below :
Sripes 4.6
Sripes 4.6
2023-4-2
DJI Wanda
Bo Christensen Posted at 4-2 03:33
Hi
Sorry for the inconvenience. We just received feedback from our engineers. Thanks for your feedback. We have reported this issue to the relevant team, this issue occurs when previewing DNG/RAW format photos, after updating the MacOS/iOS system version. Our Engineers are actively communicating with Apple team to seek for a solution. Temporarily we suggest that you view or edit the original photo through PS/LR first, we apologize for the inconvenience caused to you. Thank you for your understanding and support.
2023-4-3
Bo Christensen
Denmark
Hi
Well. it is an Apple issue, so they will need to get it sorted.
It is not related to DJI, or DJI firmware updates.. my first pictures from the drone has the same issue.
Best regards
Bo Christensen
2023-4-3
djiuser_0IUm2Ce1StvF
Flight distance : 1034262 ft
DJI Wanda Posted at 4-2 00:29
Hi there. Same issue. I have an air 2s. Zero issues prior to Mac update
2023-4-3
DJI Wanda
djiuser_0IUm2Ce1StvF Posted at 4-3 12:12
Hi, May we confirm what is your Mac OS?
2023-4-3
DJI Wanda
2023-4-3
jkrau
Same issue here. Ventura 13.3.
2023-4-6
jkrau Posted at 4-6 13:26
Hello, thank you for your feedback, we will post your feedback to our relevant team, this problem occurs when previewing DNG format photos after updating the MacOS/iOS system version. Our related team is now communicating with Apple and looking for a solution. We apologize for any inconvenience caused to you, but at present for shortly, we suggest you view or edit the raw materials via PS and LR on PC first. Thank you for your understanding and support.
2023-4-7
djiuser_rH381ZeuBMRu
Flight distance : 1638389 ft
Same issue with me following my iPhone update to 16.4.1
2023-4-9
DJI Natalia
djiuser_rH381ZeuBMRu Posted at 4-9 12:02
Hello, djiuser_rH381ZeuBMRU, thank you for your feedback, we will post your feedback to our relevant team, this problem occurs when previewing DNG format photos after updating the iOS system version. Our related team is now communicating with Apple and looking for a solution. We apologize for any inconvenience caused to you, but at present for shortly, we suggest you view or edit the raw materials via PS and LR on PC first. Thank you for your understanding and support.
2023-4-9
Nirriti
Poland
I have exact same problem with .DNG files from DJI drone and the files also appear broken after import to Final Cut Pro. (Ventura 13.3.1)
Is there any easy fix for this already or do I need to convert everything? Any updates cooming?
2023-5-2
DJI Natalia
Nirriti Posted at 5-2 14:50
Hi, there. After analysis, DJI engineers preliminarily concluded that the gain map of DNG footage affects the preview on Mac or iPhone after the system version of MacOS or iOS is updated. DNG specification is released by Adobe. To comply with relevant specifications and guarantee the image effect, gain map cannot be canceled temporarily. We recommend that you view the footage in Photoshop. We apologize for the inconvenience. Please rest assured. We will keep working with Apple Inc. to figure out a solution. Thank you for your understanding and support.
2023-5-2
maxivila
Flight distance : 9711276 ft
Uruguay
Same problem here... Apple MacMini M1 iOS 13.3.1
2023-5-8
DJI Susan
maxivila Posted at 5-8 18:06
Hi there, sorry for the issue, you may refer to our explanation on 16# and 18#.
Currently, we recommend viewing or editing the original footage with Photoshop or Lightroom as a temporary solution.
2023-5-8
djiuser_Vp0E6RLcY0ex
Flight distance : 591496 ft
Same here. Mavic Air 2S, recently started doing this as well.
2023-5-15
djiuser_Vp0E6RLcY0ex Posted at 5-15 02:50
Hi there, may I ask if you're using a macOS 13.3 or iOS 16.4 mobile device? We have reported this issue to the DJI engineers. It occurs when previewing DNG photos after the macOS/iOS system version has been updated. The DJI engineers are actively communicating with Apple Inc. to seek a solution. We recommend viewing or editing the original footage with Photoshop or Lightroom temporarily. We apologize for the inconvenience. Thank you for your understanding and support.
2023-5-15
Bo Christensen
Denmark
The issue has been fixed in Ventura 13.4 just released.
2023-5-18
DJI Wanda
Bo Christensen Posted at 5-18 12:53
Thank you for the update news.
2023-5-18
Nirriti
Poland
Yup, can confirm that it's back and working again after newest iOS update
2023-5-25
DJI Wanda
Nirriti Posted at 5-25 11:46
We are glad to hear that. Please let us know if you have any questions.
2023-5-26
g36pilot1
Flight distance : 212044 ft
RESOLVED here as well. Thanks for working this out & posting. DJI M2P and MacOS Ventura 13.3.1 to 13.4   OS 13.4 views DNG files normally.
2023-6-8
g36pilot1 Posted at 6-8 09:01
Thanks for the update. If there is anything else we can help you with, please feel free to contact us.
2023-6-9
