sthuemmel
Flight distance : 1749321 ft
Try de-attaching the camera, re-attach (check the pins while it is off). Check the connectors on top of the Gimbal plate, there are 3, you can try pushing them down with a tooth pick. You can also try removing the nose an make sure the other end of the cables are seated.
Also, try another memory card....I have read, some have caused this problem, or the socket. Take it out an push it back in. |
