DJI Avata Gyroflow Shaky Footage and Vibration
1812 6 2023-4-5
AlbertoMancini
Flight distance : 9610797 ft
Hello Dji team,i think that the Gyroscope of my Dji Avata is not working correctly.
I see, after gyroflow, some strange vibrations and shaky footage in 4:3 and in 16:9.
I will upload footage so you can see the problem.
If you check these points you will see perfectly what i mean: 00:16, 00:21 (here you can see very well), 00:27, 00:38 and so on into the video.
I tried IMU calibration, Stabilizer calibration and a lot of Gyroflow settings but nothing has solved this issue.
Happen a lot when i fly indoor really slow, as the Gyroscope isn't syncronize with the shot i'm recording.
I hope you can solve it.
Download link: https://we.tl/t-dOkkT925lr
2023-4-5
DJI Gamora
Hi, AlbertoMancini. Thank you for reaching out. If you set the FOV to wide-angle and disable RockSteady to automatically load the recorded gyroscope data after Gyroflow is enabled, and if the video needs to have a stabilization effect then you may need to set it in gyroflow. Please see Gyroflow software usage tutorials here: (https://docs.gyroflow.xyz/).
2023-4-6
AlbertoMancini
Hello! I haven't explained well. I have used gyroflow and after gyroflow stabilizzation you can notice shaky footage and a lot of vibrations. If you download the original file you can see yourself. I'm sure my avata gyroscope is not working correctly cause in some points, which I mentioned earlier, the drone glides and vibrates on the yaw axis as if the gyroscope suffered from interference and vibration.
2023-4-6
djiuser_AzYV5ZsXYIG0
Flight distance : 65919 ft
Sweden
My avata is kind of shaky when i filmed with it today and i fly it with motion controll
https://youtu.be/g5Eq-6H6v1w
You can see it in that video
3-30 10:58
DJI Paladin
Flight distance : 318 ft
djiuser_AzYV5ZsXYIG0 Posted at 3-30 10:58
Hi there. Thank you for reaching out and we do apologize for the trouble. Please check the following:
1)Check if the gimbal bracket is stuck, and if the rubber damper is broken.
2)Check if the propeller is misshapen or broken.
3)Check if the motor is vibrating abnormally after being started.
If there are no issues after the above inspection, please connect to the goggles for gimbal calibration and check if the issue persists. Please keep us posted.
3-30 20:47
Sweden
DJI Paladin Posted at 3-30 20:47
Okej i will do all these things but how i know the motor vibrate than normal ?
3-31 09:03
DJI Paladin
djiuser_AzYV5ZsXYIG0 Posted at 3-31 09:03
Thank you for your response. After the procedure, please restart the aircraft and inspect the gimbal if there is vibration after the start-up. You may perform a test flight then to check the issue further. Please keep us posted.
4-1 00:13
